The netopia 3347 will not accept my user name and password to set up the modem. I need to get into the settings and need the default user name and passcode. thanks
SOURCE: Netopia 3347
http://www.netopia.com/support/hardware/technotes/CQG_042.html
I was actually able to speak with Netopia and they recommended CQG_042 technote. The link is above.
Thanks for responding though.
SOURCE: bought used modem and don t have user name and passord
on the back panel you will find reset button. press and hold for 20sec. So your router will get back defaul settings.
SOURCE: i have Netopia 3347-02 but i have a Wireless Error help!!!
As im sure you found out the hard way, you have to swap the netopia out. You must've really snapped your lucky fingers for that one. I do this stuff all the time for a living, and I've never seen a Netopia not function correctly, a new one that is from your ISP anyway. Did you get the netopia from your ISP? or did you buy it on E-Bay, or Amazon.com, a netopia from another ISP wont function properly, but the wireless still should.
Bad modem, just swap it out. Its under warranty, its a new modem, that model number just came out last year. You wont even get charge for it. Its just frustrating when new equipment fails, and unfortuanatly, its becoming more and more common place it seems. Don't even get me started on my new motherboards from ASUS.
If its not a project, its no fun, right?...hehe
spin
SOURCE: was given an older netopia 3347-02-1006L "type
Reset it again as explained here
http://www.netopia.com/support/hardware/technotes/CQG_102.html
If necessary do it using the serial connection.
If it behaves the same then the router firmware has been corrupted and the only way to save this router is to reload the firmware by using the serial connector - a special bootloader will have to be used. You must request for it specifically from them. Use this form to get registered
http://www.netopia.com/support/hardware/firmware/updates.html?3347-02-1006dl
and then request it.
