My charger has a clicking noise coming from the front end. You only hear it when you run over a bump.
SOURCE: Clicking noise in front after hitting smaller bumps
it is the front strut i am a certified mechanic i have changed many of these
SOURCE: I have a 2006 chevy
On my cobalt (same platform) there is a known bad engine mount that clunks (like you have bad shocks) when you go over bumps.
If you look under the car from the front, you can see its a circle, (supposed to be ) filled with a rubber/composite bushing. They crack and this causes the banging.
It is supposed to look like this...
However, the rubber breaks off and your engine is flopping around.
This part needs a press to press out the old piece, so a mechanic would be the best repairman for the job.
The scraping noise is a different problem. I would suggest CV joints, but being a 2006, they shouldnt be bad unless you tow, or accelerate heavily.
I would lean toward a bad wheel bearing with the symptoms you are describing - also a job that requires a press.
You're in for quite a bill!
Figure $250 each wheel bearing and another 100 or so to fix the mount.
Dealership would be 2x that.
Good Luck!!
SOURCE: 06 dodge charger rt w 5.7 hemi engine has clunk in front end
The LX platform consists of the 300, charger and magnum.
They will all have front end noise. It's just a matter of time. This appears to be a poor design and should be recalled.
The front end should be replaced with energy suspension bushings and greasable ball joints.
The front end needs to be inspected, but here are the usual suspects. Most to least
1. Stabilizer bushings to frame. Rattle and bump sound. Not too expensive.
2. Tension struts - radius arm as some may say. Makes a poping noise and moans when driving and turning.
3. Stabilizer end links if loose to touch. Noise over bumps only.
4. Tie rods. Primarily outer. If you can turn them by hand they need changing. These make noise when braking and turning. Inner is more pronounced when steering. May cause road wander.
5. Upper and lower control arm bushings. Creak!
6. Ball Joints. These sound like an orchestra when going up a driveway. The most expensive fix on these cars. Up to 1800.00 dealer cost. They do not press out the old joints. They use a new knuckle.
7. Steering rack... another expensive fix. Moans and hisses.
SOURCE: clunk noise from front left suspension
My guess is a strut bushing/bearing, but have your front end checked out by good shop to make sure it isn't something else more dangerous.
SOURCE: Clunking noise coming from upper passenger side when I hit a bump.
If you aren't afraid of jacking up the vehicle, you can test to see where the problem is coming from. Jack the vehicle up by the pinch well (most newer cars have grooves cut out or that can be popped out behind the front wheels). When the wheel is in the air, try moving it side to side, then up and down. Excessive side to side movement indicates a tie rod end, up and down indicates a ball joint, and all around indicates a wheel bearing which would also be a cause for the clicking sound you are hearing.
Most auto shops will check this for you free of charge when you get an oil change, since they're trying to sell you things anyway.
There
are many possibilities that can cause car to make noise.
It's
actually from where the noise is coming from. Front end or rear end. From
engine area or from inside the steering or from brakes.
There
is N-number of possibilities for the car to make grinding noise or any other
kind of noise.
For
step by step troubleshooting this problem, I suggest you to refer the help
links mentioned below. Its a complete solution with proper explanation to
identify the cause of problem: ------
Click
the link below: -----
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like
driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for
Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud
noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in
the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under
dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and
front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes
Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan
belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While
Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
These will help.
Thanks.
