Two weeks ago my blackberry went blank, will not charge up and the only sympbol is a battery with a line through it. I have replaced battery and it still shows the same symbol.
Check the battery terminals...take the battery out and see if any of the 4 connecters are damaged (they break easily...happend to me twice, both times after being dropped)
SOURCE: blackberry wont turn on just shows red line through battery
Sounds like the display. There is a warranty on the unit. Contact your provider to find out what your service and replacement options are.
i have the same problem :S
I have the same problem
have the same issue...sprint said to try buying a new battery and it still doesnt work..so now Im stuck with a phone and a $55.00 battery I cant use!!!
I used it to make a phone call, then laid it down on the table. Checked it 30 minutes later and NOTHING except that stupid battery!
i put a charged battery in and then the battery sign comes up with the line through it
dropped my phone on my coffee table and it turned off and when it powered on again, battery with a red line through it, i'm going to call blackberry support and check the manual for any troubleshooting leads...i'll let you all know if i find anything
It wouldnt take any battery i put in and every time i do it shows dat symbol
mine does the same thing
