I know its old but my wife loves this 611. It stopped holding battery charge so I bought a new battery (BL-4B) and charged it via in car charger. It only holds the charge for a couple of hours and goes flat. Any suggestions?
An in car charger will not charge as well as the mains, when charging for the first time you should use the mains, and charge for at least 8 hours. If it didn't charge correctly, it will be the same low charge all the time, as the battery has a memory that makes it charge the same each time. Try charging from the mains, you might be lucky.
SOURCE: LG KG800 charging problem.
if you already change the battery;' theres no problem with the battery; i think the problem is software try to reset the factory setting if dosen't work/ reinstall software
SOURCE: battery not holding a charge
Hi try this I had a new Blackberry which required charging every single day, take out battery and press and hold the on button on the phone for a min, then put battery back in and try charging again! mine is perfect now again.
Somebody told me that it's to do with static or something that builds up and flattens the batt.
SOURCE: Nokia n95 won't hold a charge
if you bought a new battery but it has made no difference so i think it may b something so you must repair yor mobile
SOURCE: I have a Nokia E71 and the charging problem.
Have you checked the mouth of your charger? Because your charger mouth might have loose contact internally and you not knowing. But to confirm this, you have to borrow the type of your charger from a friend and test if your phone will do the same thing. And if this does not solve the problem, try loosing the phone with a phone screw driver, check if the charging port is contact the phone board well and if this did not still solve the problem, then you will have to completely change your phone charging.
Best wishes.
SOURCE: phone not holding charge with new battery
Have you try to use another charger to charge and it doesn't hold charge? if yes., no problem because it be that your charger is bad. But since it does not charge with another charger, it means the charging port is bad.
The problem with the phone is the charging port, the charging port of your phone is not charging the phone that is why it doesn't hold any charge,
All you need to do is to change the charging port of your phone and you will see that your phone will hold charge.
Take care.
