Many video fans wonder that is it possible to convert and burn MP4(MPEG4) video file to DVD directly with a DVD burning software so that watching MP4 videos on TV screen with a DVD player? but Most of DVD burning applications didn't support that converting MP4 video to DVD.
the good news is Daniusoft DVD Creator is great
MP4 to DVD Converter which can burn MP4 video to DVD easily. In following paragraphs I will show you how to burn MP4 file to DVD disc with 3 simple steps.
Getting ready Make sure you have blank DVD disk (DVD +R, DVD-R, DVD+RW, DVD-RW) and rewritable DVD-ROM and downloaded
Daniusoft DVD Creator Go to install and running it. The interface is as simple as Window Movie Make.
Instruction to Convert MP4 videos to DVD (3 steps)Step 1. Loading MP4 videosClick "Import" to load MP4 files from computer, or you could simple drag the files into the application (Multiple MP4 video files can be added at a time). If the MP4 files have been added successfully it will appear as thumbnail view on the left sidebar.
Step 2. DVD menu making Click "Menu Template" to customize your DVD menu. There are different styles of built-in templates, frames and buttons for your choice. To apply a template, frame or button, you can just double click it. You can even add text, background music and background image to customize the menu.
Previewing MP4 video Just for make sure everything goes as your plan you could have a video preview before burning it to DVD.
Step 3. Convert MP4 to DVD disc Once you have previewed your video and nothing wrong, now you can convert to DVD disk. Go to set TV Standard (PAL/NTSC) on "Setting" option and output Aspect Ratio (4:3/16:9) on "DVD setting bar". Click "Burn" and then select your DVD drive (if you have more than one DVD drive on PC) and Click "Start" to burn your project.
Tips: The volume of DVD use is shown on the bottom side. You can select DVD type of "D5" or "D9". If the video size is exceed the DVD capability you can reduce it by setting output quality. E.g. select "high quality" instead of "Best performance".
That it, with Daniusoft
DVD Creator, you can convert MP4 to DVD and even make your own DVD menu in 3 steps. It's easier and faster than other ways of converting MP4 files to DVD. And the software also can burn other common Video files like WMV MPEG MOV FLV MP4 M2TS, etc to DVD and is fully
compatible with Windows 7. Now, enjoy watching MP4 movie on home DVD player.
Same problem as I read by someone else, I have Windows XP and computer tells me I need to have Windows 98. Can anyone help?
My one just froze on the startup with the hour glass sign. Somebody please help
yea same problem can any1 help us on this it sucks
