At any given moment, all electrical alarms and warnings sound and all lights come on , all climate controls and radio setting return to factory settings as if the battery as become disconnected, door locks unlock and relock , clock resets to 12 :00 compass and temp reading show all lines on digital display in mirror, seems that anything under computer control just stops and resets
SOURCE: fuse box
THERE IS A FUSEABLE LINK BETWEEN FUSE BLOCK & BATTERY, IT IS BLOWN. THE FUSE IS AN INTERGRAL PART OF THE WIRE HARNESS.. YOU NEED TO REPLACE THE LINK. SIMPLY CUT OUT OLD LINK, SPLICE IN THE NEW ONE.
SOURCE: Power Door Lock Problem
The last post by maddog1321 was exactly what I had with my right rear door. The electric locks would not lock and unlock, and you almost couldn't do it manually without my feeling I was about to break something. I took the door panel off, oiled everything and got no relief. Finally, I saw the above post and drilled out the aft-most pop-rivet. THE WINDOW WORKED PERFECTLY! I didn't drill out the forward (closest to the handle) pop-rivet because I wanted to do one at a time so the solenoid would not fall out of place. I then put a new pop-rivet in place of the one I drilled out. I then reinstalled everything and the locks work like new.
SOURCE: temp sensor and compass not displaying on my 2003 yukon xl
Yes. Look in the Fuse Panel inside the Truck. Use a Good Maglight or LED Flashlight and Hold it Behind the Fuses to see the Blown Ones. It is usually in an AUX Outlet. Also check thr Fuse Relay Box under the Hood for a Blown Fuse using the Same Method. See if there is a Relay for this also. If so, Replace it. Let me know if you need any more Help! Please Rate my Response, I need all the Help That I can Get!
SOURCE: No power to inside of the vehicle!
Check the body control module under the hood, should be on the drivers side fenderwell. Perform wiggle test to harness first, then remove module and reinstall. for proper contact. Check for power in and out, 12 volts.
SOURCE: all the power controls on the drivers side have
THIS FUSE FOR THE DOOR LOCKS IS NOT LOCATED UNDER THE HOOD. THEY ARE UNDER THE DASHBOARD ON THE DRIVERS SIDE OR NEAR THE FRONT DOOR HINGES. HOPE YOU FIND THEM. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
