Was at the end of a 9 hr drive. stopped at a light and truck stumbled when starting off. drove about 1/2 a mile and truck died and won't restart. cranks, but won't start.
SOURCE: 1989 Chevy K2500 - idles fine but stalls out when put into drive.
Sounds like the injectors may be bad or just really dirty. You say that the truck is only used as a plow truck, so I would assume that it sits alot. If you dont add any fuel stabilizer to the tank, the fuel will start to degrade and the will gum up your injectors. One thing you can do is to pull the air cleaner assembly off and look at the injectors while the truck is running. Look at the bottom of the injectors while it is running. The injectors shouldbe spraying fuel with a fan spray of fine mist. If you see any drips of fuel in the this fine mist, that injector is at least dirty or on its way out. I would recommend that you change your fuel filter and then get some fresh fuel and the purchase some Seafoam fuel injector cleaner from your local parts store. Dont mess around with anything else. GET SEAFOAM. If it is in a plastic bottle it is not strong enough to do anything. Seafoam is in a metal can. Dump the seafoam in and run the truck as much as you can. This will help clean out the injectors.
SOURCE: 2000 GMC Sierra cranks wont start
Hello, 9-10 volts is not enough to keep a modern vehicle running. Taking in consideration the age and model of this truck, it could easily be an alternator failure.
I hope this helps.
CYA Gator241
SOURCE: 2005 chevy silverado won;t start.
i had the same problem, and it turned out the coil pack was moulding inside wich stopped the spark all together, i ended up changing my coil pack and putting on new wires because the ends connected to the coil were very corroded and that cures the not running part just fine
enjoy
SOURCE: 2004 silverado cranks but won't start
try the spark plugs do you smell fuel you may want to try starter spray make sure battery is fully charged.write back well try something else good luck thanks
SOURCE: 2002 express 1500 van, will not start
remove dog house locate test port and install guage should be 45-60 psi
