1. Turn on a device and, if applicable, insert video
media, (e.g., cassette or disc).
NOTE: Please read steps 2-4 completely before proceeding.
Highlight or write down the codes and device
you wish to program before moving on to step 2.
2. On the remote control, press a device key once
(e.g.,
AUX,
VCR,
TV, or
CABLE). Press and hold
SETUP until the selected mode key blinks
twice, then release
SETUP.
3. Use the
Manufacturer’s Codes (starting on
page 11) to locate the the type of device and
brand name and then enter the first four-digit
code for your device. If performed correctly, the
selected mode key will blink twice.
NOTE: If the selected mode key emits a long blink, the
code is invalid. Repeat steps 2 through 3 and try
entering the same code again.
4. Aim the remote control at the device and press
POWER once. The device should turn off. If it
does not, repeat steps 2-3, trying each code for
your brand until you find one that works. If it
still does not work, try searching for the code
(see
Searching For Your Code on page 20).
NOTE: If the device does not have a POWER key, press
the (Play) key.
5. Repeat steps 1 through 4 for each device you
want the the remote control to control.
The potential codes for your Sylvania TV are:
0054
0030
0381
Here is the manual. The codes are on page 11 if you need more.
http://www.cox.com/Fredericksburg/digitalcable/Cox_d4.pdf
Hope this helps :)
