It has no room for even a pinky and no it doesnt have a velcrow plastic cover. its plastic but its like screw locks or push in clips. and r a pain to get off and theres no room for a pinky even in that.. and how can u just turn the thing if u cant get ur hand in there?
How you doing. you have to pull the plastic clips behind the lights up and off bye hand or plyers. Should be 2 or 3 yes its a pain but has to be done. Then you can pull the headlight housing out to replace the bulb. hope this helps you. [email protected]
SOURCE: change headlights 96 oldsmobile 88
some cars have a plastic cover over the headlight area, all you do is pull it off. it's velcro. you don't need much room because all you need to do is twist the bulb and pull it out.
SOURCE: how do you change a
the headlite cluster comes out the front to expose the replaceable bulb in the back..do not touch the new bulb glass..it will shorten the life...kev-mn.
SOURCE: 1999 oldsmobile delta battery changed but won't power on
If everything else checks out Ok in the ignition system (electrical) and if the engine and transmission turn freely,that sound like you might have starter drag.Check to see if you have good connections at the starter.I know its new but check your battery for 12 volts,good connections,ect.
SOURCE: The wheel cover has a key or key lock to lock the wheels.
Not that you haven't checked, but most of them stored in the glove box or the trunk where the spare is kept.
Anyway, if you are looking for a key, they come in various colors, but you must specify color needed [red, green, yellow, silver,black]. Pop the emblem in the center of the hubcap and see if there is a colored circle or if the bolt head has a color dot on it. Once you find the color you need, they are available online or local for ~ 5-10 bucks. Check your parts stores, hubcap/wheel stores, tire shops for help finding or using one.
SOURCE: I need to remove the interior door panel from my
most of the screws will be located at or near the armreast and under the map popcket on the lower door (if it has one) just work gingerly in pulling off the pannel using the proper tool. If you take your time you will find all of them work slowly and look before you pull. There are clips at the top of the door that are holding it in place to remove the pannel you will have to move it in an upward direction.
