The battery does not keep it charge, it goes down ever day
SOURCE: 2003 HUMMER H2
Had the same problem. i have to re-place my front wiper motor they are all connected.
SOURCE: my 2003 h2 hummer will initally not shift from
Check the linkage that goes from the shift lever down to the transmission. It sounds like somewhere along the line, it has become disconnected or has broken.
if that parts are clean then It sounds like you have a shift control solenoid that has high resistance causing the hard shift you describe. Scan the PCM for trouble codes if none are present you could have a internal transmission problem.
SOURCE: my 2006 h2 hummer battery keep's going dead i just
If its putting in 110 volts then you have a altinator problem.Regulater over chared the battery.The battery needs to be replaced you have damaged the cells.Thats why it want hold charge.Before you do fit a new battery change the altinator.Hope that was helfull.
SOURCE: battery goes dead after two of sitting, bought new
there might be some kind of short drainin your battery or your alternator may not be workin not chargin the battery
