TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands.
TIME AND DATE
A. Press and hold SET. SECONDS digits will flash.
B. Press SPLIT/RESET to set SECONDS to zero.
C. Press MODE to select HOURS.
D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM.
E. Press MODE to select MINUTES, press SPLIT/RESET to advance.
F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display.
G. Press SET when done.
BASIC OPERATIONS
Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate
watch face. In any mode, press MODE to view time display. Press any button to stop alarm or
timer beeps.
INDIGLO
INDIGLO
CHRONOGRAPH
A. Press MODE until CHRONO appears.
B. Press START/STOP to start.
C. Press SPLIT/RESET to record lap time. Display pauses.
D. Press MODE to resume display of lap and split time (automatic after 10 seconds).
E. Press START/STOP to pause chrono.
F. Press START/STOP to resume.
G. Press START/STOP to stop.
H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times.
I. Press and hold SPLIT/RESET to reset chrono.
MODE MODE
START/
STOP
START/
STOP
SPLIT/
RESET
SPLIT/
RESET
SET SET
CROWN
COUNTDOWN TIMER
A. Press MODE until TIMER appears.
B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat;
Countdown and Start chrono).
C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits.
D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance.
E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS.
F. Press SET when done.
G. Press START/STOP to start timer.
H. Press START/STOP to pause, press again to resume.
I. When timer is stopped, press SPLIT/RESET to reset timer.
Watch will beep when countdown reaches zero.
ALARM AND CHIME
A. Press MODE until ALARM appears.
B. Press SET to select HOURS. Digits will flash.
C. Press SPLIT/RESET to advance digits. Go through 12
hours for AM or PM.
E. Press SPLIT/RESET to advance. Repeat for MINUTES.
G. Press START/STOP to turn alarm on or off.
H. Press SPLIT/RESET to turn chime on or off.
When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed.
Alarm will repeat every 24 hours until deactivated.
INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE
A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964)
electroluminescent technology used in the INDIGLO® night-light illuminates watch face at
night and in low light conditions.
B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate
NIGHT-MODE® feature.
C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds.
Chime on
Alarm on
If your watch is water-resistant, meter marking or ( ) is indicated.
Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface
30m/98ft 60
50m/164ft 86
100m/328ft 160
*pounds per square inch absolute
WATER AND SHOCK RESISTANCE
WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER
WATER.
1. Watch is water-resistant only as long as lens, push buttons and case remain intact.
2. Watch is not a diver watch and should not be used for diving.
3. Rinse watch with fresh water after exposure to salt water.
4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to
pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
I got the exact same problem and now it wont turn on at all as battery is dead and i cant get the phone back on at all and i dont want to pay the 50 dollar deductable just to get a new one hate verizon sometimes, but it is better than sprint just not on insurance as with springt id have new phone immediately
Mine also counts down 10 seconds and then shuts off. I just received this one in the mail 2 days ago, it's already ******* up. I hate Asurion, they are the WORST cell insurance company to have.
when i turn my phone on it says "use genuine battery" then counts down 10 seconds and then shuts off, its not that old and it pissing me off that it is not working
