I want to replace the indicator unit on my Mk 5 VW golf but cannot get the wing mirror cover off. How do you do this.
Ok very carefully pull off the mirrior blade. The mirrior blade is clipped but EXTEMELY fragile and will break if forced. From there remove the 2 heated blade wires. The cover is also clipped as you will notice after that is removed. You have to pry with a plastic tip between the cover and hosing near the body of the car while pulling the clips in the housing you see to lift the cover straight up. Once this is done you'll need a t-10 torx screwdriver to remove the lower portion. These screws are when you're looking straight down. With this assembly off you can access the 2 other little screws holding the flasher to the bottom cover. Remove the wires and the little clip and there you go. Installation is reverse.
will not start
