1995 Dodge Dakota Logo
Anonymous Posted on Oct 30, 2008
Truck dies while driving
Driving along at any speed the truck will just stall or more like shut off. I have to pull over , turn the key off, wait 5 seconds , ( not 4 not 3 ) restart it and it starts right up but does it again and again. I have had the crankshaft position sensor replaced, dist pickup plate ,dist cap and rotor, wires, o2 sensor, map sensor, fuel pump, auto shut down relay, pcm, battery,starter,ignition switch,throttle body gasket,and redid all soldered connections in the wire harness. This has been going on for 2 months and now its gotten worse. Truck stalls as soon as I put it in gear and wont restart at all unless I rock the truck back and forth like I am trying to flip it over on its side and jump in and turn the key . It will restart but will shut back off as soon as I put it in reverse or forward.
  • Anonymous Oct 31, 2008
    same type of proplem did not replace anything yet the truck shuts off it did restart after about five secounds latter but will not restart acts like no fuel getting to carb engine turns over good just no start oct. 31 08 fist time it has done this
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 393 Answers
  • Posted on Nov 12, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
393
Questions
0
Helped
195994
Points
885
Check for clog in fuel pump pick-up screen(inside gas tank)
Truck runs fine then dies while driving then will start back up and run ok.
About 56,700 results (0.76 seconds) Search Results
    GMC Sierra 1500 Questions - Truck suddenly stops running ...
    www.cargurus.com > Questions > GMC > Sierra 1500
    CarGurusJul 11, 2013 - Truck suddenly stops running, acting like it's out of fuel. ... start it and let it run until it dies then check the pressure and shut the key off. ... Was running fine and then turned off as if the ignition was turned of. .... Well mine was a loose battery connection that just shut down the vehicle completely while driving.
    1998 1500 5.2 Shuts Off Randomly - CarGurus
    www.cargurus.com > Questions > Dodge > Ram 1500
    CarGurusAug 29, 2011 - I let it sit for a second then tried to start it back up and it wouldn't start.... 2006 ram 1500 randomly dies while driving 13 answers ... truck started outrunning fine but would randomly die. wait a few ... Used GMC Sierra 1500".
    GMC Sierra 1500 Questions - started stalling and dying ...
    CarGurusJul 28, 2008 - The truck starts and dies. Have to give a little gas to keep running.While driving have to 2 foot it so it won't die. Wants to die when I come to a ...
    Engine Dies and Then Starts Right Back Up
    www.justautorepair.com/chevrolet/blazer/stalls-starts-up
I can be driving along and the car just dies, I pull over and wait for about 5 minutes and it will start back up and run like nothing has happened. "Check Engine" light never comes on. I borrowed a code...
02 is not the problem you stated there where cel on when the car died. They could have been pending codes not related to the stall. Common on this car is crank, cam sen. If the crank fails it will stall and not show a crank sen fault code.
Truck keeps dying out. Driving along and it will just die, (Pop start it while still moving and it'll run or sometimes turn the key and it'll fire back up) Dies all the sudden. Replaced the coil. Twice....
check for loose connections/fuse at the key/ ignition switch. Check for loose connection where the ignition gets the power (starter motor terminal)
'04 L300-3 Stalls randomly and won't start until I wait about 5 min. Then starts normal
try replacing fuel filter , and next time you go to start it turn key on let it sit for count to 50 then start see what happens
1996 mercedes c280 dies when put in drive
Engine stalls or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Have a 2001 S-10 flex fuel 5 speed. Truck likes to stall out (nothing on dash comes on), shuts off like someone shut the key off. Have replaced: plugs, wires, crank shaft senor, and fuel filter. Can be...
Wiggle the key in the truck when the truck is running. Your losing fuel or spark. Check connections in the fuse panel. Check wiring harnesses for tight connections. Email me back. [email protected], Good Luck Jim
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
