You should check first the fw version. Tha last fw version is v 3.2.4. if the fw is updated it, replace de fan, if fan is ok, replace ECA controller. InFocus IN1100 Projector
toner density sensor voltage is less than 0.5 volts or more than 4.5 volts.
cLEAN THE
1) Toner density sensor 2) Flow of the developer at the toner density sensor area
Hello Rickd971, there is a FW update that will allow you to program your remote to the TV. Please send me a quick email to [email protected] with the serial # TW# and a contact # in the event I need any other information and I will forward you the FW along with installation instructions.
FW Found means "FirmWare Found".
An update to the blu-ray player was located and they want you to download to update your player's firmware.
After it updates, power OFF your player, wait a couple of minutes and power ON. This is like re-booting.
I have flashed just 1 DVD drive, years ago. It was easy when you knew the trick. The download site should have told you how. You must get the firmware to read and remember the update flash.
That said, I stopped flashing firmware long ago. If it ain't broke, don't fix it. I was given this info and I pass it on. Lots of folks update, upgrade and flash their way to real trouble.
there must be some problem with the firmware,you need to update your fw or you can use some tool to restore your fw,such as pc3000 or HD Doctor for salvationdata
Fixed. Called Garmin. It seems that version 4.90 FW on the Nuvi 350 (which came shipped on my 350) has a bug where it cannot communicate with the Garmin software either to update maps or update FW. Tech from Garmin e-mailed me a patch that I copied into the Garmin folder on the Nuvi itself, via USB and Windows Explorer. I then rebooted it; the patch installed itself which then allowed the unit to communicate with the map upgrade software and all is well. 2009 map update is now installed and the Nuvi is working fine again. Haven't tried upgrading to newer FW yet; will probably leave well enough alone.
