SOURCE: miller syncrowave 200 makes buzzing noise from spark gaps.
Odd noises other than the normal sound of the spark gap working are often the result of dust and junk inside the case of your welder. That it also bogs down when it gets warmed up (fan comes on), also points to a need for some "annual maintenance" stuff being done.
Completely isolate the machine from the building power supply, pul the plug, open the circuit breaker, do whatever it is that makes the machine have no connection to any power.
Take off the covers with a 10mm or 3/8 inch socket (can't remember which)
Use a shop vac to **** out all of the dust and debris out of the machine. Low pressure (40 psi) air can sometimes be helpful to dislodge caked on dirt. Avoid any metal tools near the capacitor bank inside the welder.
Wipe off the fan blades.
Clean the spark gap electrodes by inserting and removing a matchbook cover, a business card, or a piece of white cardboard several times. Inspect the electrodes and adjust them according to the manual that came with the welder.
Check all of the power wiring connections for tightness by gently tugging on them. Look for signs of overheating on the power connections and on the internal connections to the welding terminals. Check the range switch for heating too.
With the cover still off, reconnect the power and turn the welder on. Look for obviously vibrating laminations on the main input transformer. If you see one buzzing back and forth, or if you notice lots of wear and tear on the varnish coating of the laminations, shut everything down and repair the loose laminations with some anti-fungal high voltage varnish.
Turn the welder off, disconnect the power, and put it all back together. Then turn the power back on and weld something, if htere is still a buzzing noise you'll need a Miller tech to solve the problem, you likely have a bad input transfirmer.
Regards,
Carl
SOURCE: dirty weld
clean your metal with a good peace of the green scotch guard scrub pad prior to the weld.Also try turning up your gas and move a little faster when using filler wire,rember to much heat causes a darker dirter weld.hope this helps
SOURCE: Miller TIG Welder Syncrowave 350XL has no digital read out...
it's free for you to download.
http://www.millerwelds.com/products/tig/syncrowave_350_lx/
SOURCE: I have a Hobart tig TG301. I have no gas to the torch
Most likely it's a problem with the solenoid used to control the gas inside the machine. you can get a new one from hobart and put in for about half the cost of what they charge at your local. Just look at you owners manual and get the part number for the gas solenoid.
Replace the gas solenoid. If you need one I'll send you a good used one off of another Maxstar 200 for just the shipping cost. Send me the serial number of your machine just to be sure they are copacetic.
