SOURCE: Need to remove the fan to replace the water pump
you need to get a fan clutch wrench to remove the fan you can get one at any local autozone or murphys parts stores
SOURCE: my 1999 gmc savana van turns over but does not
could be a bad fuel pump, or fuel pump relay. they are having problems(a lot) with the ethanol in the gas on GM products.Fuel pumps sales are through the roof at parts house on GM's. Have a pressure check on your fuel system. That is probably it. Add a can of Seafoam to your fuel every 3000 miles to alleviate this problem.
SOURCE: 1997 GMC Savana cutaway van 3500 fuel filter
cartrigde type is locted at the top of the crossmember just forward of the gas tank on driver side of the vehicle,,,,,,,,non cartradge type located on front of the fuel tank..
SOURCE: Hello, I have no air flow
The first thing I would check is the blend door actuator. This is located under the dashboard towards the center, move the controls while looking underneath so that you can locate it. Once you locate it call the dealer for the replacement part before you take this one out.
