your problem with the gear selector is in the item 25 these are 2 plastic bushings that wear out and cause the gear selector feels loose, you should also check the item 27 this item has one or two screws loose and cause the gear selector feels loose
Item
Part Number
Description
10
3F609
Tilt Wheel Handle and Shank
11
7361
Column Shift Selector Lever Plunger
12
7210
Gearshift Lever
13
3D657
Steering Column Shaft
14
7B071
Transmission Control Selector Lever Plunger Spring
15
7G357
Gearshift Lever Pin
16
7212
Shift Tube
17
N806582
Tilt Column Pivot Screw
18
7C464
Transmission Control Selector Lever Spring Clip
19
7E400
Gearshift Tube Bushing Clamp
20
Spacer (Fixed Column)
21
3E729
Steering Shaft (Fixed Column)
22
3F527
Lever Assembly (Manual Transmission)
23
3F530
Pin (Manual Transmission)
24
3F752
Brake Shift Interlock Solenoid
25
7335
Gearshift Lever Socket Bushing
26
7A216
Transmission Shift Selector Position Insert
27
7302
Transmission Selector Lever Arm and Support
28
7E395
Shift Cable and Bracket
29
7210
Gearshift Lever
30
3E691
Steering Column Lock Pawl
Please, where do I look to find the linkage? Sorry to sound stupid but for this, I am. Do i look under the hood or is this something in the steering column?
