I note missing fire in spark plug cables wend motor is hot
For spark plug problem,click the help links provided below :---Car has no spark?http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html ------------------------ Car
not starting or turning over indicates towards multiple possibilities. It can
be issue with battery or weak battery. But if battery checks out ok, then it
can be starter issue or faulty alternator or problem with low fuel pressure or
no spark at spark plugs due to dirty spark plugs or faulty ignition
coil or injectors getting cracked or dirty and needs to be cleaned. To
confirm the problem, the basic troubleshooting is required. Click
this link below and follow the troubleshooting:------ http://technoanswers.blogspot.in/2012/02/car-starting-issues.html --------- This will help. Thanks.
------------How to Replace Spark Plugs?http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
-------------Car cranks, has spark but will not start?
The spark plug firing order for car?http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
----------How to gap spark plug ?http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html-----------Spark plug Replacing for?http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
-----------How to identify number one spark plug on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
---------How does the spark plug wire go on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
---------Spark plug Firing Order Diagram?http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
SOURCE: 2004 Kia Rio Cinco problems
Hi
If the check engine light is going on and off then it is very highly likely pointing to a misfire, and this could be due to any number of things, and your best bet by far is to have a code read done as this will give you information as to the cause of the problem, if not point you directly at the problem itself.
It could be coil packs, spark plugs, injectors, crank sensor, cam sensor, any number of things.
Regards
Geordie
SOURCE: 2002 Kia Rio Timing Belt
yes, this is VERY IMPORTANT, this is an interference engine, meaning the valves and the piston cannot be in the same place at the same time,or it will bend the valves.then you are looking at a major repair job,think or it as insurance on your engine. please rate my fix as i strive to be the best,questions,get back to me
SOURCE: 2007 kia rio - owners manual missing
check this site
http://manualspace.com/kia-rio-rio5-2008-owner-s-manual.htm
SOURCE: what is the proper spark plug gap setting for a 2002 Kia Rio
Hello mfriesner71; my name is Roger and I will answer for you. The correct plug gap is 0.027 to 0.031.in. Any gap between these will work fine. Just make sure they all gap the same. Should you need further help please just ask. Please rate the answer. This way I know it was helpful. Thank You for using Fix Ya. Roger
