After running for a few min.Gas valve would cut off and on causing some flame roll out. (seemed to get worse tha hotter the heat exchanger got) Started out with by-passing all limits an pressure switch... Ran great, had good flame nomore intermitten GV. And no more flame roll out... Then i bypassed just the pressure switch, again ran great? I checked flue pipe, heat exchanger, replaced pressure switch, ran a bead of hi-temp silicone around induced draft fan motor seal.. I guess what im tryin to ask is can a exchanger cause the pressure switch to open an close intermittnly?????? Help :/
SOURCE: Goodman GMP075-3 ignition problem
OK, if the furnace is not lighting for even a few seconds, you have either a bad gas valve, bad wire, bad control module or no gas. The pressure switch is not the issue. Check all wires to the gas valve and look for 24 volts across them when the ignitor glows and you hear the click. Then test for 24 volts to ground. It could be a bad ground wire.
Test while the unit is firing with a meter. you should have 24 volts going to gas valve. If you do and no gas is coming out, you have a bad gas valve. You will need a gas pressure test kit to install a new one correctly.
SOURCE: big old Hydro Therm boiler rolls out flame at
This may be normal it's hard to tell from your description , The flame could possibly rollout for a second or 2...depending on the venting , how far the vent is from the chimney etc....you shouldn't hear a "Mini Explosion" you may hear the gas ignite with a bit of a woooosh...depending on the size of the boiler this could be quite normal...Boilers can be dangerous when they get plugged up or dirty....although Hydrotherm makes an EXCELLENT Cast Iron Boiler...I would still have it checked by an expert to be on the safe side....you should also have a "Slow Opening" valve which would eliminate that problem if the valve is working correctly , but it's possible it was replaced at some point with a regular opening valve and this could be the reason as well
SOURCE: need help with a goodman gmt070 furnace
it may be clogged at the barbed fitting on the induced draft motor where the pressuer switch tubing connects. take a paper clip and **** it out make sure you can stick it thru freely till you can feel the Inducer wheel then reconnect and try again.
