Lexmark does not recommend the use of refilled cartridges. These tend to degrade print quality and cartridge/printer performance.
Please note that once a cartridge is refilled, it can no longer register its ink level.
It could be that your cartridges need some cleaning. On your computer, launch the Lexmark Solution Center. Click Start menu > Programs or All Programs >Lexmark 2500 Series > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print again.
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink
cartridges can cause them to leak, thus clogging or even damaging the print
head. Any damage to your printer caused by refilled ink cartridges may not be
covered under warranty”. Please use genuine Lexmark cartridges for best results.
Hello! 28 and 29 are not meant to be refilled. They can physically be refilled, but they won't work. That is because Lexmark has put in a smart chip that doesn't allow refill. You need to buy 28A and 29A or 34 and 35, those cartridges can be refilled with no problem.
If you find my answer helpful, please vote. Thank you!
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
I have the same problem. According to another site I visited you will not be able to solve your problem by refilling the 28 cartridge (black ink). You will need to purchase a 28A ink cartridge which is refillable.
I just ordered a Lexmark X5495. The carts that come with it are throw aways (or return them to Lexmark to be remaned.) You can use cart. # 28a, 29a, 34 or 35 to refill, the latter two being the high yield carts. And yes the printer manufacturers are playing a cat and mouse game with us. I normally use Epson because it's easier to circumvent the tricks they employ. I understand Canon is an inexpensive printer to run also. HP and Lexmark are the costliest products to operate. There is a utility for Epson called SSC ver. 4.30 that gets around the safeguards by resetting the cart. chips and a whole lot more. Someone needs to write a utility for HP and Lexmark to replace the standard driver/ink monitors that are designed to siphon off our wallets quicker than they do ink. One more trick I've heard: when the printer is looking for a new cart have a spare cart handy and put it in in the printer. The printer will now think you have ink in the cart.(whether its empty or full) Now trying swapping it out for a refilled cart and see if that works. The point is this: the printer wants to see a new cart serial# ,not the same one that was just being used last.
