just install windows 7 it automatically correct the drivers.Or else just a driver finder do this job.If u need exact drivers feel free to contact me with correct machine id and brand name,and also sound card name. Thanks
You need to install the sound driver for you PC. This will help you to get the sound correctly.
If you mention the name of your PC, I will provide you the correct link to download the driver.
Try to download yourself, if not able to means please let me know.
If you go into the sound card properties make sure you have the driver for it.
The driver is the only thing apart from a faulty sound card that will stop it from working correctly. If you have the correct driver then check that the sound card is actually working correctly and is switched on.
Hai, Are u installed any sound driver for your pc.Try to install the sound driver with the motherboard cd that came along with a new pc.First put the cd on the cd rom and automatically install all the required drivers.It will work deffenitely.
have you install windows xp sp2
run the set up of the sound driver, it is available on the cd provided by the Acer,
dont do anythying when the setup is running, even its ask for update, reboot the laptop sound will definatel come
can you teach me how to find my missing computer soundcard , cause i try to find it in internet but still can work it,and course you know in internet to many soundcard driver in there, the correctly i'm don't know my sound card name. thanks for you help, 845GV-M
You can find the sound driver for this motherboard at this website. Just click on either the Global Server or the Europe Server depending on your location and save the file to your computer to install.
Thanks for using fixya!
Hope I have your solution precisely correct.
Sometimes you may install other drivers that you system may recognise but not identify with. ensure that that the drivers are correct and that you soung ouput device is plugged iinto the correct socket. Also make sure that your sound device is enable in the device manager in your control panel and that you system volume is on and up. If these dont work then your sound device could be damage, best option then is to install a pci sound card and your problems will be solved. let me know how you go. thanks
cheers, hope it works...
