open the battery door on the remote, theres a red button. also there is a red button on the wii in the SD card slot press the one on the Wii then the one on the Remote.
First you will need to check a few things, just to make sure what the actual problem is.
*Check to see that all cords are properly plugged in.
*Make sure the sensor bar is properly center above or below your tv set.
*Make sure that nothing is blocking the signal to the sensor bar.
*Make sure that the batteries in the remote are in good working order.
*Make sure that there are no wireless devices close by that might be interfering with the signal.
If after all this the remote is still not working then it probably needs to be re-synced.
Turn off and unplug your wii console for a few minutes.
*Turn the power back on and when
you see the the safety screen open the small flap on the front of the
wii console. Inside you will find the red sync button. Press and hold
the red button down for 15 seconds.
* Then remove the battery cover from the wii remote, inside you will see another red button.
* Press and release the red button, the blue lights on the remote will start blinking.
* Quickly press and release the red sync button on the wii console.
* The remote will stop blinking and it should now be synced.
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
Press the Power button on the Wii console to turn it
on.
Open the SD Card Slot cover on the front of
the Wii console.
Remove the battery cover on the back of the Wii
Remote you
wish to sync up.
Press and release the SYNC button on the inside of the SD Card
compartment
on the console. Press and release the SYNC button just below the
batteries
on the Wii Remote.
When the Player LED blinking stops, the syncing is complete. The
LED that
is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Sync it.Open the front cover on your Wii, then push the red button there, then open the batteries cover on your Wii Remote and push the red button there.If this not help press and hold the red SYNC button on console for 15 seconds. This will clear all synced Wii Remotes from the console.Then try to sync Wii Remote again.
You may need to resync with your console. Take the battery cover off, and open the little door between the eject and reset buttons on the front of your console.
With the machine started and running, press the red button in your wiimote, then quickly press the same color button in the panel on the console.
you will probably have to sync them. Open the battery cover on the remote and open the front cover of the wii console press the sync buttons at the same time. Hope this helps
Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
Turnthe power of the Wii console ON. When you see the Health and Safetyscreen, open the small flap on the front of the Wii console to find ared button labeled "SYNC." Press and hold the SYNC Button down for 15seconds. This will clear all the syncs on the Wii, allowing you to geta clean start to begin the process described below.
After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
Withthe first Wii Remote you wish to sync, remove the battery cover on theback of the Wii Remote to find a small red button just below thebatteries.
Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
