The bulbs are 2 filaments right? there has to be 2 wires unless there is a ground wire (3 wires) every trailer has to have a Running light, Left turn, right turn, and ground. th ebrake and turn signals work the same wires. you dont say what kind of truck you have, but some trucks have fuses for trailer lighting. put the 4 way flashers on and see whats wrong. if you have flashers you should have brake.
The most common bulbs #1157 have 2 filaments and each has it's own Spring Loaded contact in the Socket. Remove the Bulb, using a 12 Volt Test Light to check that you have power to Tail light contact, then have someone apply the Brake and check the other terminal for 12 Volt power. Be careful to not short the probe to the socket housing! It may be possible that a wire has been severed somewhere between the front and rear of the trailer. Check for damage underneath the trailer or wherever the conduit is routed. Having driven 18 Wheelers, many trailers have their own fuses at the front of the trailer. Check wherever the cable that connects to the tow vehicle enters the trailer. Also check the terminals at the tow vehicle for power. Check individual fuses in the Tow Vehicle. I drive a 2004 Silverado and it has separate fuses for Trailer Left and Right Turn signals as well as for running lights. What kind of connector is used on the Trailer? ATA Trucking style or Bargman like an RV trailer. Remove the cover and check to see that there is a good connection to each pin. Is the Jacket on the Cable damaged and a wire severed? Anything between your trailer connector and the rear of the trailer is suspect.
