Cell Phones Logo
Posted on Sep 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The phone is set on vibrate for txt but I want a sound when I receive a txt. Where are the settings for that?
Anonymous
Level 2:
  • Expert 94 Answers
  • Posted on Sep 17, 2011
Anonymous
Expert
Level 2:
Answers
94
Questions
0
Helped
29992
Points
355
Hay,
You didn't tell us the name and model of the phone but you can go to Menu on the phone, look for settings, depending on the phone type, the settings to change your sms tone could be in Tones,Profile etc.
for example,In my Nokia, its tones under settings. if u still are unable to change it, u can send me your phone model.
Thanks
When i recieve a text message there is no ring tone or vibrate
plz check your sound setting.for that
instructions are:
1. go to your phone's "setting".
2. enter into "sound".
3. "ok" or "click" on "vibrate".
4.and if you want ringtone at received time than go to "phone ringtone" below vibrate option.
4answers
No New Email Alert Sound or Vibration
BEWARE!! Don't get trapped with the scammers. visit official AT&T help Website or call them for proper guidance.
https://www.att.com/
1 888 211 0387 ATT Email Customer Service Phone Number
tip
How to Fix iPhone Not Vibrating?
If you are in a meeting or attending a special event, you probably set your smartphone to silent mode to avoid any distractions from your phone. But what if there is an emergency? You will miss the calls and texts from your phone and then regret it later after realizing that it is a very important matter that needs to be discussed with you.
If you don't want to disturb your meeting or the people around you when your phone receives calls or texts, then choose to vibrate mode instead of silent mode - at least you will be notified if your phone receives any notifications. But what if you are using an iPhone and you learned that the vibrate mode is not working. What would be the reason behind it?
/uploads/images/fix-iphone-not-vibrating-undefined-undefined-0.jpg
Fix iPhone not vibrating
Now, if your iPhone is not vibrating when it receives calls, texts, notifications, or when you switch on the ring or silent mode, then you need to learn some of the solutions to fix this issue. Here are the 3 effective solutions that you need to know.
Solution 1: Check the iPhone Vibration on Sound and Haptics Settings
One of the basic things that you should learn about your iPhone is how to set the phone settings, especially the vibration mode. If your phone is not vibrating, go to your iPhone settings then navigate to the sounds & haptics option and check the vibration mode from ringtone to text tone - if off, turn it on. Then disable the focus mode that restricts the vibration of the app's notification.
Solution 2: Check the iPhone Vibration on Accessibility Settings
After enabling the vibration in the sound and haptic settings but still your iPhone is not vibrating, then go to the accessibility settings and check the vibration mode is turned on.
Solution 3: Fix iPhone not vibrating via iOS System Recovery
If the first two solutions didn't work on fixing the vibration issue of your iPhone, don't worry. With the iOS System Recovery, all iOS errors will be fixed including the vibration issue of your iPhone. This reliable tool can quickly solve any type of iOS error.
on Jul 14, 2022 • Miscellaneous
Phone want vibrate wheN I get a txt message
It is not automatic that phone will vibrate when you receive a message. You have to set the phone. For that you go to settings in the Menu and then select phone settings. Go to Message Alert and select Vibrate and Ring option. Click OK/Save depending the display on the screen
Sep 23, 2010 • Cell Phones
Message Vibration not working
make sure you have "txt messages" set to ring/vibe not "calls to line 1 ring/vibe"
1helpful
2answers
How do you put the LG VOYAGER VX10000 on vibrate
the other solution is not what i think they are asking.
there are many ways to put the phone on vibrate:
1. closed: press the phone icon and hold the # sign.
2. open: hold down the Z key from the main screen.
3. open or closed: press the down volume key on the left side of the phone until it says vibrate.
My txt arent getting received
hi.. go to settings in ur phone and check whether ur incoming message setting is turned on or off.. thank u
LG Secret SMS text alerts sounding only once
In the settings change the interval to continuous.
Voicemail and Txt alert sounds
then you will need to have the firmware reflash or take it to the store and hvae them explain why it is still doing that.....the phone firmware may need fixing.
Ringer
go into profile and set ur message setting 2 silent and ur ringing tone 2 set anytone./.it wont make noise. reply me
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
