To reset your Nintendo Wii:
1. First. soft reset of the Ninetendo Wii. If you Nintendo Wii has
just started acting up and there is no reason to perform a hard reset
then follow this instruction. Simply press the reset button and hold
down for 2 seconds on your Nintendo Wii Console.
2. Now, for the
more advanced hard reset. Interestingly, the Nintendo Wii has NO hard
reset facility to be accessed through the machine or via buttons. The
ONLY way to hard reset your Nintendo Wii is to UNPLUG it for 5 minutes.
Once it is unplugged it resets itself and your badly behaving Nintendo
Wii should be restored.
From
Nintendo Wii
What appears to have happened is the sensor within the mote has dislodged and been moved out of alignment the smacking both sides works but its only a stop gap solution, you need to open up the mote and tac some solder onto the connections, this will prevent it from going out again, also check the sensor bar is not loose as the cable from the sensor bar can sometimes become loose if it's moved around alot.
doesn't seem to work...
