Hi Error E6 means flood switch
activated, check the Inlet hose and whether the connections to the water inlet
water valve is loose. Also make sure there is no inlet valve body leak. Check
for damage to the fill or drain hoses. Try and reset the error code by
following this procedure ?
To Clear the current Fault press the Key lock button until a beep is sounded.
This action moves the Current Fault into the Previous Fault while clearing the
Current Fault. To Clear the Previous Fault press Key lock once more until the
beep is sounded. Warning: Once a fault has been cleared, it is permanently
removed from memory and cannot be recovered. Press Power to advance to the next
level. Hope this
helps...please post back for further assistance. Daniel
