SOURCE: cant get the application buttons to work in windows 7
From Fujitsu's Support page for the ST5112 you need to install all of
these to get the App buttons working Properly
Button Driver
Button Utilities
Hotkey Utility
And you might also need the Hotkey Driver
That's how I got my St5032D app buttons to work.
If all fails you can also try the vista drivers.
Good Luck
SOURCE: Hi i have a siemens pc tablet stylistics . Can i
If they were on the ball they will have xp versions of the drivers just incase people want to downgrade to xp. What you need to do is find the support page for the model and see what drivers are there. The important ones will be the video, the network (wired and wireless), sound, and pointers or screen interface. If you can find those it will work pretty normally. Those are the drivers that usually have to be loaded from the manufactuer as the built in microsoft versions won't work. There were a few XP based tablets so thats not the problem, its getting the screen functions and the touch screen to behave properlly.
This will take a bit of hunting but you should be able to find the drivers. Just save them off to a usb flash drive and then install xp, run the boards drivers or system info file driver first, that lets xp know what its talking to. Then just run all of the drivers until you run out of them ;-] (yup its as boring as it sounds).
To find your drivers start with the support page for the tablet. So go to the manufacturers website www.Fujitsu.com, click on your country so it uses a local site,then select support near the top, then computers then laptops and tablets. This will vary a bit on the differant web sites they have. You should eventually see a selection box, with laptop and tablet pc, select tablet, then in the second the model, and in the third the type or version. That will show you the available downloads for yours.
