Check fuel pressure, should be 40 psi.
try 2 things
spray starting fluid in air intake to see if it will stay running. It's fue then.
Try turning key to on nd wait 5 seconds for system to build pressure and pump to shut off. Turn key off, wait for relay clcik noise or 10 seconds. then turn key to ON again and wait 5 seconds to build pressure again. Then start engine. If it starts better, you have a bad check valve in the fuel pump or a bad pressure regulator on the fuel rail (unlikely).
report back
