SOURCE: I have a Trillium Breadman
I just pulled out the instruction manual, and it says:
E:02 Displays when you press Start button:
The Breadman is too cold. Unplug the machine and allow it to heat up to room temperature, then try again.
I don't know how you're supposed to let it heat up to room temperature if you've had it in a room with a nice room temperature with it unplugged, but that's what the manual says.
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
