John Deere 22HP VTwin 48" Riding Mower Logo
Posted on Aug 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When mowing with my John Deere riding mower, it leaves a narrow strip of grass uncut in the center.
shawn zaiontz
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Nov 29, 2014
shawn zaiontz
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
Helped
11309
Points
10
Sounds like your blades are worn out n need replacing
raycabralsr
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 93 Answers
  • Posted on Aug 19, 2011
raycabralsr
Expert
Level 2:
New Friend:
Cheetah:
Answers
93
Questions
0
Helped
19580
Points
243
Try sharpening the blades on the mower. dull blades can sometimes cause a strip of uncut grass
1helpful
Mower leaves strip of grass unmowed in center of deck. This is a model X300 with newly sharpened blades
Check the center blade to make sure it spins freely when the deck belt has been removed. The spindle may have frozen up.
1helpful
Husqvarna yth24v48ls leaves streaks of uncut grass
What are the size of the streaks? and where in the 48 inch swath?
Why does my riding tractor leave a strip of grass that isnt cut
It is probably an indication of worn mower blades. Installing new ones should solve the problem. Hope this helps.
Bob
2helpful
I have a John Deere LA105 Riding Mower and when I mow it leaves a strip of grass in the middle. Left and right sides are cutting fine. I have taken the blades off and shaarpened them and have leveled...
jack the tractor (using a tractor jack) or remove the deck, measure the blade tips against each other where they meet in the center of the deck and see if they are the same tip to tip. Bearing wear, a bent deck or blade can make them cut at different heights in the center.
Uncut grass in center & higher grass cut on right.
Hi, this may sound obvious but make sure the new blade is the same type as the old one and make sure it is not fitted upside down. Spin the blades and make sure the tips are level with each other, this will tell you if the deck is straight where the blade spindles mount. Regards Phil.
2helpful
I have a MTD Pro riding lawn mower that I
the only way to fix it is fit the right blades
they have fitted the wrong blade's to it,,,
the blades should overlap when cutting the grass they cannot crash into each other as there are (timed up) not to do that the new blades they fitted are to short so you have no over lap on the gutters that leaves a strip of grass left uncut between the blades,,
call them out to put this stupid mistake right,,,
Oct 25, 2009 • Garden
1helpful
The riding mower does not mow small strips in the middle of the row being cut. It almost looks like a bad haircut? This happens when I am going fast or slow. It is not a mulcher. This problem is...
Sounds like it is time to replace your blades, I have 2 scotts mowers made by john deere both machines are 9 years old I mow comercially and get 4 to 5 sharpenings the they need replacing.
1helpful
Mower leaves a uncut srip of grass through the center of the mow area!
The blades need inspected and sharpened,one could have a bent tip or just dull,if youve had someone else pull them off and reinsall them already check to make sure one of them isnt installed backwards,dont laugh,Ive seen it happen.
Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The motor isn't on full throttle.
2. The blade is upside down.
3. The grass is too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
