Here are the specs for the welder from the maker of the unit which is Chicago Electric, this is a line of tools owned by Harbor Freight Tools. Here are the specs:
This is the ideal starter welder! Comes set up for Flux Core Arc Welding (FCAW) for hassle-free operation at the start. Add gas components for full MIG welding with shielding gas later on. As you can see it is designed to run on 240 volts AC
Input Voltage: 240 volts AC, 24.5 amps, single phase, 60 Hz
Rated output current: 30 to 160 amps
Rated output voltage: 18 volts @ 110 amps
Max open circuit voltage: 19-30 volts
Duty cycle: 15% @ 110 amps
Wire capacity: 0.023" to 0.030"& 0.035"
Wire feed rate: 192 to 306 inches per minute
Weldable materials: Mild steel, low alloy steel, and stainless steel (not suitable for aluminum)
Material thickness: MIG: 22 gauge (1/4" thick), FCAW: 22 gauge (5/16" thick)
Includes: 2 lb. spool of flux-cored wire, two spare contact tips (0.023"/0.035"), handheld face shield, chipping hammer with wire brush, multi-purpose wrench
Below you will find a pdf product user manual at the web link.
http://manuals.harborfreight.com/manuals...
Hello again, please refer to page 27 of the user guide for the wiring diagram, I show the two 110V leads go to posts A and D, (Top of page in diagram) the third lead is grounded to the chassis. Here once again is the link to the user guide for the welder.
For technical questions you can contact Harbor freight tools directly at this number.
1-800-444-3353.
Thanks for the solution-so according to the manufacturer; I need to change the existing cord and rewire the unit (incoming power) for 30 amps and make the existing neutral post with another leg so that the incoming voltage is actually 220 vac ?
Yes, I did not get the manual for the welder or info with it. I will feel better now by wiring it as per your instructions and the manufacturer's instructions. I will also change the 220 v plug to a twist, or a 220v plug so that it does not accidently get plugged into a 110 vac receptacle. Thanks again for your help and I copied the manual with the link you sent.
