ASUS Eee PC 900 Notebook Logo
Posted on Aug 14, 2011
How to format asus eee pc 1001ha? - ASUS Eee PC 900 Notebook
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1053
Points
6
To format the hard drive, you would remove the hard drive from the Asus EEE 900 and connect it to an other computer. Than you would format it from there.
2helpful
Charging asus eee 1001HA netbook
Does your unit power on at all or is it just not charging the battery?
If it's just not charging your battery the likely cause is the battery has just gotten used up, replacements are usually between $50 and $89 CAD
tip
Good day PRO, I WAS TRYING TO INSTALL WINDOW 7 ON MY Asus Eee PC...
"Help!!! How to recover my forgotten laptop password?" Situation is so urgent! Then search solutions online: laptop password reset, how to remove laptop login password? Carelessly, we forgot laptop password, then we now concentrate on how to unlock laptop password methods!
How do I recover laptop password on Windows Vista?
- Remove laptop Windows Vista password from Safe Mode
A. When laptop starts, please press "F8" key.
B. At the "Advanced Boot Options" windows, choose "Safe Mode with Command Prompt" and then login Safe Mode with available administrator account
C. Input "net user", press "Enter" key and then all the accounts will be listed.
D. Input "net user Lisa 012" (Lisa is the forgotten account name and the 012 is Lisa's related account password.), press "Enter" key to finish unlock laptop Vista password.
E. Input "shutdown -r" and press "Enter" to restart laptop, then we can login "Lisa" account again.
How to find laptop password for Windows 7
- Bypass laptop Windows 7 password with built-in administrator account
A. Power on laptop PC and press the key: F8.
B. At the windows of Advanced Boot Options, opt for "Safe Mode with Command Prompt" and confirm with key: Enter. Then PC starts Windows.
C. Select "Administrator" account shown on the account screen, and then access the windows - Administrator: cmd.exe.
D. Input command: net user Merry 123 and confirm with Enter. (Merry is the account required to reset password; 123 is the new password for account Merry).
Please note that the administrator account will be useful only we had set it enable. (The default status is disable.)
How can I Break password on laptop Windows XP
- Get into Windows XP laptop by default Administrator account
A. Press "F8" when laptop computer starts.
B. At the "Advanced Boot Options" windows, choose "Safe Mode" with arrow key and confirm with Enter key, then PC accesses Safe Mode.
C. Click "Administrator" on the Windows login screen.
Please note that if we have set the Administrator password before, we need to input the changed password instead of leaving "Password" field blank.
D. Start - Control Panel - User Accounts - Select the locked account and change password for it.
E. Restart laptop and login with the account newly reset password.
The above ways are referred to system with available account (default/built-in account or other accessible accounts with administrative privileges). While, if there is not other accounts to help us, how to reset laptop password?
Unlock laptop password with Installation disk: if there is not important data for us, we can use it for password unlock.
Laptop password bypass with password reset disk: we can use the disk only if we create the disk before lost password for the related account.
DIY a laptop password reset disk now: It is the last but not the least solution on laptop password recovery!
We need a CD/DVD/USB disk and an accessible computer to burn a .iso image file from Windows password recovery software! Take one of the most top-rated tools - Ainorsoft Windows Password Recovery Corporation as example:
A. Download Ainorsoft Windows Password Recovery Corporation and burn its .iso image file into a CD/DVD/USB Flash Drive from an accessible laptop;
B. Set PC with password locked to boot from burned CD/DVD/USB Flash Drive;
C. Reset forgotten laptop Windows password to a new one with the burned CD/DVD/USB Flash Drive.
Now, once we forgot laptop password, the last method will always make sure we reset password for laptop easily without IT expert knowledge.
Source: http://windowspasswordrecovery.net/article/laptop-password-reset.html
on Jul 21, 2011 • Computers & Internet
ASUS Eee PC 1001HA factory restore
start tapping f8 @ boot to see if you can get to boot menu, if it doesn't work then you'll have to get an external dvd player and boot from that to do a repair.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Asus Eee PC 1005HA wontl load OS
what key do you see during the boot up process
you should see a certain key it will be very quick you might have to restart a few times to get a good look
try pressing the delete key
hope it helps
1helpful
I need webcam driver of windows XP for Asus Eee PC 1001HA netbook. when all of my netbook was formatted since then this was not reinstalled. mahesh
On this page:
http://support.asus.com/Download.aspx?SLanguage=en&m=Eee+PC+1001HA&p=20&s=1
Select your operating system and you will redirected to the download page.
On this page you will find all the drivers for your model.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
To find ASUS Eee PC 1001HA Driver
Drivers can be downloaded here: http://asus.driversdown.com/asus-drivers/s_93_1.shtml
My asus eee pc 1001ha web cam is not working.I tried few ways 1.unstall and install drivers 2.installed new version of driver 3.flash bios new version 4.registery repared 5.checked for...
now l use wendows7 in my asus eee pc1001ha after download wendows 7 before my camera lose in table how can l attach in wendows my web came camera,
1helpful
2answers
BIOS POST message cannot be displayed and Setup does not run
As soon as your computer turns on, start pressing F2 simultaneously until it enter the CMOS setup.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
