SOURCE: TEAC MC-D95
weak or exhausted optical lens or laser assemly,needs replacement or adjustment,see a doctor.
SOURCE: Teac dvd player
how old is your machine? if old enough isuggest you change the lens and try if it can load faster than before
SOURCE: Teac GF-350 CD Shelf System
Firstly double check that the recordable discs you have bear the label "Digital Audio" on them as per the attached picture. Secondly what happens when you go through the finialise procedure in the manual? Do you see the ?FIn--d? display when you select the finialise button? Do you see ?NO TOC? and ?REC? indicators blinking at the next step? Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: My Teac dvd/cd-rewritable w28e CD-RW, won't read any discs!
if you just installed this device you will have to go to the utility manager and make sure all the functions are turned on, do you have windows xp. what os are you using and i can give you instructions how to go this.
SOURCE: My Teac R-H500 tape deck will not play tapes
The belts will have failed. You will need to replace them for the deck to be reliable. If you are mechanically minded I can talk you through it... You giving me a FixYa rating will help my profile and loosen my lips on how to overhaul your deck. :)
