Condition
A/C stops cooling and blows warm air
when the vehicle is idling for an extended period of time such as
sitting in traffic.
Cause
Inadequate airflow over the condenser may cause this condition.
This problem is a known issue, See Bulletin No.: 01-01-39-004A
http://www.grandprixforums.net/website/Docs/TSB/99-01-39-004B_Air_Conditioning_Odor.pdf
http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
runs lean and idles rough?
http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Idle Air Control (IAC)
Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows
hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
While stop engine idles
like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
This
will help.
Thanks.
Idle Air Control (IAC) Valve Replacing?
Replace Idle air control valve?
Test Idle Air Control (IAC) Valve?
Idle Air Control (IAC) Valve operation?
Car overheats and Air blows hot at idle?
While stop engine idles like cylinder missing?
This will help.
Thanks.
Car
------While stop engine idles
---------This will help.Thanks.
