Shure SM58 Professional Microphone Logo
Question about Shure SM58 Professional Microphone
How do i sync my shure slx2/sm58 mic to my shure pg4 receiver
Posted by keify on
Fred Yearian
  • Shure Master
  • 5,603 Answers
The short answer is you don't. The slx2 and the pg4 are not compatible.
Posted on Mar 25, 2013
5 Related Answers
night71
Lyle Siemens
  • 328 Answers
SOURCE: feedback
That is a great mic. It has a lot to do with the room your in and acoustics of it. If you are too close to your PA or monitor, it will also feedback. Lowering treble and reverb will also help.
Posted on Nov 04, 2007
Anonymous
  • 3 Answers
SOURCE: shure sm58 mic does not have full power
You should consider a microphone with more power to get the volume you need. I can personally recommend the CAD C195 Cardoid Condensor microphone. It has great output. The only downsidefor most people is that they don't have phantom power. This is what gives the mic its boost. In order to get the most out of any micrphone, you need to have a preamp, an equilizer, and an output. The output is your PA system that drumbanger mentioned.
But since you are using a Peavey, here is my strong recommendation. Get a mini preamp, and hook it up to your Peavey. You can use a Behringer 2mic mixing board for your preamp. It's small, and it can sit right on top of the Peavey.
XENYX 1002
http://pro-audio.musiciansfriend.com/product/Behringer-Xenyx-502-Mixer?sku=631262
CAD C195
http://pro-audio.musiciansfriend.com/product/CAD-C195-Cardioid-Electret-Condenser-Microphone?sku=270775
The reason why I suggest the two-mic XENYX 802 and not the 1 channel 502, is that the 1 channel doesn't have phantom power.
In order to connect the XENYX to your Peavey, this is all you need. You can get one at radio shack for pretty cheap.
http://accessories.musiciansfriend.com/product/Mogami-Pure-Patch-RCA-to-14-Mono-HiDefinition-Patch-Cable?sku=339031
Posted on Mar 22, 2009
Anonymous
  • 6 Answers
SOURCE: i have a shure sm58 wireless microphone when i
Unfortunately the sm58 capsule is very hard to get apart without damaging the contact surface.
You would have to take the contact side apart 1rst
bend all the little tabs away which hold the brass plated disk in place
then its a matter of edging the disk out....CAREFULL any scratch is bad!
Once you have the disk out you will need a 1/4" socket to remove the shaft bolt,
unsolder the green and yellow wires taking note where they were soldered.
Then the element can be pulled out.
What to after that, I'll let that up to you.
Be wary, you will void warranty.
Posted on Jun 30, 2009
Anonymous
  • 417 Answers
SOURCE: shure sm58 just started outputting very low volume
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
Posted on Apr 15, 2010
Rick
  • 611 Answers
SOURCE: I have two Shure sm58
If these are wired SM58 mics, they will probably need to be sent to Shure for repairs. The cost to repair is less than purchasing a new one, and they will usually just send you a new mic.
Posted on Aug 30, 2010
The SMG8 is synced but will not keep signal if the mic is not right next to receiver (PGX4)
There are many reasons this could be happening. Call Shure Tech Support at 847-600-8440. They can help you troubleshoot. Have the mic nearby when you call them.
How can I sync a Shure T2 mic to a LX4 receiver
There is no sync. They simply need to have the same frequency listed on their sitickers.
Sync issues with pg4
Since there isn't any detail provided, call Shure (800-516-2525) for help in troubleshooting. Have the mic nearby when you call.
Sync shure pg58 mic to shure pg4 receiver
Since there are no details provided, call Shure (800-516-2525) for assistance in troubleshooting. Have the mic nearby when you call.
Mic
The PG4 is a receiver. So it should never be transmitting.
Unable to syn my slx2 mic to reciever
Make certain it is an SLX4 receiver in the same exact frequency band as the SLX2.
How do I reset the channel and group on my SHURE SM58?
The easiest way to change the microphone is to sync it to the receiver.
Top Shure Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
