Ok first try to shine a bright light on the screen when u have no picture but have sound if the picture is there but din you either have bad lights inside the panel ( not worth fixing or possible a bad inverter board since you left no model number I cannot help you any further
Posted on Feb 20, 2018
SOURCE: lcd tv screen stays black, but with sound
just open up the tv 2 the main bord then look for a littler green button press it and then plug it in and it will work i did it 2 mine
Posted on Mar 23, 2008
SOURCE: No picture after 20 mins on LG LCD Tv
i have a 32" lg hd flat screen an it now does the same thing i got it on boxing day an its not even 5 months old
Posted on May 15, 2008
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
SOURCE: Screen Problem
hi....Your tv picture is managed by several boards, the two specific ones are the ysus and the xsus. The Y controlls the horizontal pixelation and the X the verticle, if you are having horizontal problems then its the Ysus thats faulty, on this particular set, the Ysus board has two accompaning buffers that are particularly troublesome. I've had more than one of these sets in the shop recently with the same ailment.Sounds like your buffers are starting to go out. The screen is split horizontally by the two long skinny buffers attatched to the Y main, if the bottom one has one leg in the grave you'll be getting a partially black screen or no picture at all. The colored lines running through the screen are more typical of a failing buffer. Are you interested in taking this set apart and putting a couple hundred into fixing it? When buffers go they usually take the Y main too. Worse case scenario you're gonna be out about $350 dollars to fix it yourself. Best case, a ribbon is loose on the bottom buffer and with a dismantle you'll be able to connect it again..
thank u rate me!!
Posted on Feb 12, 2009
SOURCE: Screen goes black, still have audio
I first changed the 220uf capacitor with no luck. I flipped the BURN switch to on and the set has been working great for a week now. Daughter left it on for about 20 hours overnight with no problem. Anybody have an idea what those 4 tiny switches are for? I have heard these type of switches called "dip switches". They are tiny white switches in a yellow block on the lower left side of the upper circuit board. The top one was labled 40", the next one down was labled 46", the 3rd one was 4 letters "EW" something I think, and then the bottom one was labled "BURN".
Posted on Aug 12, 2009
Jan 21, 2018 | Toshiba REGZA 47HL167 TV
Jun 18, 2017 | Samsung LN46A630 LCD TV
Mar 04, 2011 | Televison & Video
Feb 01, 2011 | Samsung LE40R74BDX 40 in. LCD Television
Oct 29, 2010 | LG 42LC2D 42 in. LCD HDTV
Mar 22, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Sep 15, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Jul 31, 2008 | Televison & Video
Jan 30, 2008 | Koss KS3102 System
51 people viewed this question
