RCA P52939 52" Rear Projection Television Logo
Question about RCA P52939 52" Rear Projection Television
P60921 it's making beeping sounds - RCA P52939 52" Rear Projection Television
Posted by sdominguez28 on
Sonny Berry
  • RCA Master
  • 8,617 Answers
Thats almost always caused by the Flyback transformer and HOT transistor replaceing those should solve the issue. You can get the RCA repair kit with flyback and HOT for your model from www.tvrepairworld.com
Posted on Aug 04, 2011
My Peugeot 106 makes short beeping sounds when shutting down. Car stars normally, but again when shutting down beeps four times and stops. What does this mean?
this might sound crazy but have you got a aftermarket sony stereo fitted because my dads stereo makes this anoying beeping sound everytime he turns the ignition off, if so its nothing to worry about :)
2answers
My acer aspire laptop makes a beep sound when swith on button is pressed
beep are of manyh types how many beeps it gives?????? reply me fast so that i can help u
My clipper will only make a sound that sounds like this 'beep beep beep' please can somebody helped me
I had the same problem, beep beep beeeeep. Take all your music from mp3 player to a folder in your PC and transfer it back to mp3 and that should do it
1helpful
4answers
When I go to turn on the computer, it just makes a beeping sound.
Beeping sound leting you something is wrong with some hardware. As for what,, listin to the beeps.. also depends on motherboard... here is a link http://www.pchell.com/hardware/beepcodes.shtml
But best way is to open up machine and make sure all the hardware is hooked up tight. If that does work look at the code list then go from there.
1helpful
Oven keeps making a BEEPING sound - only way to
This will occur when there is a control fault detected. have the oven control board replaced asap.
Aug 20, 2009 • Ovens
I CANT GET NO SOUND I THINK IVE INSTALLED MY SOUND CARD REALLY ANNYOING IT MAKES NORMAL SOUNDS BUT WHEN I WANA LISTEN TO MUSIC OR YOUTUBE OR JUST NORMAL THINGS IT DONT WORK ONLY MAKES BEEPING SOUNDS WHEN...
I find it annoying when people post in capitals, it's considered bad manners akin to shouting.
Check that the sound card is seated correctly in the slot on the MoBo.Don't "think " you've installed it correctly. Be sure you have.
Beeping at start up indicates a problem. The beep codes can be a number of long or short ones or a combimation of both. To interpret these we need to know the number and combimation of beeps and the make and model of yoor PC. The OS would help as well.
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
3helpful
Beeping Sound
Maybe the horizontal IC output are damaged need to be replaced
2helpful
Oven beeping
hi my kenmore stainless steel black top keeps making a beeping sound and says F11
5helpful
6answers
3 beep sound-no booting
system is on but no display. yes i did heard sound 3 beep sound from the motherboards.
Open Questions:
See all RCA P52939 52" Rear Projection Television Questions
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
