Question about Peg Perego IGED1084 Santa Fe Train
Have lost charger 4 ride ad go thomas will any 6v charger fit it and where do u charge it anyway is it the hole at the back of the train
Posted by b_ostins on
Mark
    New Friend:
  • 10 Answers
It looks like the charger has a specific plug terminated on the end so I would suggest buying the manufacturers replacement part. It can be purchased in the UK from the below links for around £35 or slightly cheaper form ebay but from a seller in the USA (third link below).
The charger model number is MECB0037.
http://totcars.co.uk/detail.aspx?ID=848
http://www.pedalpusherslimited.co.uk/pedalscat/peg-perego-replacement-6v-charger-p-515.html
http://www.ebay.co.uk/itm/220796543022
Hope this helps.
Posted on Aug 04, 2011
  • Mark Aug 04, 2011
    To charge the battery it looks like you disconnect the battery from its plug inside the battery compartment and connect the charger directly to the battery through its plug.
My Thomas 6v Ride -On Train works, but VERY slow. It sounds like its really struggling to go. I have TWO fully charged batteries so I know its not the battery. Everything else on it works great...
It sounds to me like your battery needs to be replaced. The batteries lose their ability to hold a full charge after some time (especially if they've sat for a long while without a charge). You can get the battery tested at a trusted shop, but it might be more econimical to just replace the batteries with fresh batteries and see if that solves the problem. New batteries will charge much better and hold the charge much longer.
Sep 23, 2013 | Peg Perego Gaucho Superpower
Need a battery charger for thomas the train ride on
you can get one on ebay for about $6 shipped, just look for a 6v1a sla charger
Nov 24, 2010 | Peg Perego IGED1084 Santa Fe Train
Charged but wont run
please verify that the battery is showing more than 6v on a multimeter, your charger might be bad
Oct 08, 2010 | Peg Perego IGED1084 Santa Fe Train
Hi where would i get a replacement battery 6v as the one we got does not hold its charge many thanks lisa
make sure its not your charger thats bad, check it with a multimeter and make sure its putting out at least 6 volts
May 05, 2010 | Peg Perego Santa Fe Express Ride On Train
Hi i need a 6v charge for a ride on thomas
ebay jst get a 6 volt 1 a sla charger i think they're about $6 with free shipping
Nov 08, 2009 | Peg Perego IGED1084 Santa Fe Train
Peg Perego Santa Fe Train motor will not work.
you can try a couple of jumper wires from the battery directly to the motor to see if the motor still works
Mar 19, 2009 | Peg Perego Santa Fe Express Ride On Train
Need Diamec 6V 4.5AH battery charger for Thomas the Train
Call peg perego directly. You want to make sure you get the correct one , you can mess up the battery with a slightly different charger.
Jan 12, 2009 | Peg Perego IGED1084 Santa Fe Train
Peg Perego IGED1084 Santa Fe Train Logo
915 people viewed this question
Top Peg Perego Toys Experts
Marvin
Marvin
Lawrence Oravetz
john h
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
