SOURCE: SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
SOURCE: Sony DVP-NC675P Multi-disc DVD player will not play dvd's
have you tried cleaning the laser at all?
SOURCE: I have a Ford AU
more than likely something got stuck or broken ..
You will need to open it up and see if there is anything you can notice that may be causing the problem. more than likely the loder. if you think you can move it back into place or frmove the jammed components then by all means do. if not take it to an electronic technician.
SOURCE: input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
SOURCE: car radio replacement
Does the radio power up but give no sound? If this is the case, you need to make sure the factory amplifier is first turned on. the aftermarket radio should have a remote turn on lead for amps. The Dodge caravans sometimes have Infinity sound systems in them and there may be a green wire with a red stripe in the factory side of the radio plug. This should be amp trigger. 12volts to this wire should give sound. If at all unsure, please consult a local stereo shop.
