Well, you really have 2 questions. Let's tackle them one at a time.
1. The Lightscribe is where the CD/DVD burner will burn the top side with the laser to create a laser inscribed image or label or design, etc. I know this part might be obvious. Your PC should have a separate lightscribe software installed if it came with the drive. Sometimes it is packaged within the main burning program that you normally use to burn DVDs with.
If you installed the drive later, look up the support page for the drive and they should have the software available for download. Lastly, you can probably find lightscribe software for free in many many places.
2. Compaq is owned by HP now so I did a search and I'm attaching the link to your specific PC's support page where you can download manuals and make sure all your drivers for your computer are updated.
Compaq Presario SR5450F Desktop PC
Compaq Presario SR5450F Desktop PC User Guides
https://support.hp.com/us-en/document/c00208298
The 2nd link refers to Lightscribe label printing processes.
To get user manual(s)/support/information for your sr5450f, go here:
https://support.hp.com/us-en/product/compaq-presario-sr5400-desktop-pc-series/3686675/model/3686679/manuals
For software/drivers for your sr5450f, go here:
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-sr5400-desktop-pc-series/3686675/model/3686679
For the LightScribe software, click here:
http://ftp.hp.com/pub/softlib/software4/COL10053/pv-28739-1/sp26468.exe
Good luck.
SOURCE: how to completely reinstall windows xp on compaq
For that you will need a bootable CD with Winxp.
Before, be shure you will have an a CD or DVD with drivers for Video and Audio card, network etc, the kits instalation files for programs you use and the serial number for license
Insert your disk with winxp instalation on cdrom or dvd unit and reboot.
When you will begin to install windows, format the partition.
SOURCE: My Compaq Presario desktop will not burn CDs
Perform a system restore and take the computer back to a time before the problems started with burning, or you can download a different media player and try burning with that, real player as a good bit of software to use for burning and Nero is too (Nero is a devoted burning suite)
Get real player here >>>>>>
http://uk.real.com/realplayer/
Get Nero 9 here >>>>>>
http://9-burning-rom.com/index.asp?aff=101&camp=gg_nero_uk&se=google
Good luck
SOURCE: Lightscribe Technology
If it does it will say on the front.Do you have the original paperwork ?that will tell you if it does and secondly if the software was factory install the lightscribe software it should be there under program files.
good luck
SOURCE: Type of video card
The Compaq Presario SR1630NX desktop computer, has a PCI-Express x16 slot on the motherboard, for a PCI-Express graphics card.
The Presario SR1630NX came out in 2005.
PCI-Express 2.0 technology came out January 15, 2007.
The Presario SR1630NX uses the PCI-Express 1.1 technology.
You can use a graphics card based on the PCI Express 2.0 technology, however.
PCI Express 2.0 is Backward Compatible with PCI Express 1.1
You just won't get the full capability, of a graphics card based on the PCI Express 2.0 technology.
Will you notice?
NO
SOURCE: problem with hp compaq presario sr5450f desktop pc
Sometimes it happens that you start the computer and get black screen having this message, "NTLDR is missing press Ctrl +ALT +DEL to restart". This mostly happens when the virus infects your computer, because most of the viruses attach themselves to the NTLDR files. This can also happen due to power failures, problem in master boot sector, corrupt bios settings, or some other problem in the boot.ini file. These files play a very important role in rebooting the system and if there comes any problem or they get corrupted by some virus or for some other reason, then they do not allow the hard drive to boot. However, its not that much difficult to fix this error, as all you need is to get your installation cd and then need to follow some simple steps. This will definitely help you in fixing your boot loader to the working state.
*First, you need to get your installation cd and then place it in your hard drive and restart your system.
*After restarting the system, you will get message "Press any key to enter setup". So, follow this message and press any key, this will take you to the setup. However, there could be some different scenario as well depending on your bios setting. This is because of the fact that if you have not given priority to your hard drive then it would not boot in this way. For this, you need to change your boot device priority and its better that you set this priority to your CD Drive.
*Once you enter the setup and it loads the entire program, then you need to press the R key, which is for repairing the windows installation. This action will take you to the dos mode where further processing will be done. In the dos mode, system will ask you about installation place. Most of the people install their operating system in the C drive, which comes at number 1 option, so you need to press option 1. However, if you have so many partitions or you have installed the operating system then you need to choose the option according to your drive name. Here you need to enter your password as well, but if you have not set any password then you can simply press enter.
*Then there will be a c:\WINDOWS> command in a dos mode where you need to write, "Copy d:\i386\ntldr c:\windows. However, if you have different place of your installed operating system then you will write the address of that drive. This is the whole process and now you can eject the cd and can press exit to restart the system. Now this process will copy the correct NTLDR file from installation disk to your hard drive by making your system in the working condition.
Remember to fix your Windows registry with RegInOut Registry Cleaner and PC Optimizer. The Intel software partner program, RegInOut thoroughly clean your registry and helps to avoid Windows errors and crashes. If you place the registry protection in place it will give a great boost to the Windows internal functions.
To start a seventeen seconds download of this amazing program just go to this location and directly download the program from Intel Software Partner Reginout
