Franklin MWD-1470 Dictionary and Thesaurus (MWD 1470) Logo
Posted on Aug 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My device will not turn on even after changing battery, how can I fix this problem
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Franklin Master 102,366 Answers
  • Posted on Feb 23, 2012
Franklin Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428896
Points
622693
First, make sure the batteries are in the correct orientation. Then hold the CLEAR button and press the ON button. If that doesn't do it, straighten a paper clip and gently press the reset button located on the back in a pin-sized hole below the book card slot.
1helpful
Fix my sattellites none in me pats
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
How to turn on gps keeps saying gps turned off
Need to change to english on my 1300
How do i change starting position on my 710 tomtom
Vauxhall vectera 55 plate cdti 1.9 6 speed not starting engine turning centeral locking working battery strong electrical problem ????
Jan 21, 2011 • GPS
2helpful
My plenio vxa-3000 the navagation wont work but everything else will how do i fix it
3helpful
Since a few weeks ago, when turned on, "GARMIN"
My touch screen is not working. after a long time
if you kept the batteris inside for long time it could be that they leaked inside when it happend there is some damage inside.
update for the OS sometimes helps
i fix this calculators
[email protected]
4helpful
My Liebert PSA itON 600 UPS keeps beeping when i turned it on
To figure out what's wrong with the UPS, first you have to do a few things.
When calculating the rating a UPS can handle, it's voltage x amperage. If it's Watts multiply the number by 1.67 to give the rating of the device.
Add up all the devices (use the power supply rating in the computer) as well as any other device, and add them up.
If this rating was exceeded, then you have overloaded the UPS. If it was too long that you did this, then you wore out the battery.
When a UPS beeps even when not connected, that means the battery is very weak.
If the battery is more than 3 years old, it will need to be changed. If the online tests of the unit were done and the battery doesn't need replacing, then other parts of the UPS need fixing.
Check the battery.
11helpful
3answers
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
Top Franklin Office Equipment & Supplies Experts
nexrad_chris
Arnie Burke
Arnie Burke
k24674
Are you a Franklin Office Equipment and Supply Expert? Answer questions, earn points and help others
