Question about Bosch Measuring Tools & Sensors
Bosch DWM 40L How does it reset? I have changed batteries , all it is showing is 888.8 ?
Posted by paul34839 on
2 Related Answers
Chad Triggs
  • 5 Answers
SOURCE: My Bosch DWM 40L angle
Open the the moveable arm and make it straight (180 degrees) or in line with the other.Take the screw off of the black cover at the elbow (1 screw). Lift from the round part and lift off. Then loosen the two screw just inside the cover. This will allow the flywheel to spin and you should now get a read out. If the flywheel does not spin then you need to replace that piece. Gently tighten the two screws and put the cover back on. Hope this helps!
Posted on Nov 07, 2011
Jack Spooner
  • 1015 Answers
SOURCE: Bosch DWM 40L, Cannot seem to resetit,it reads
The first thing I would do is to replace the battery after cleaning the contacts thourghly. Hope this helps. Thank you.
Posted on Feb 24, 2011
My bosch washing machine is displaying F21
Then REPLACE CARBON BRUSHES (something happend with the commutator on the motor, in most case the brushes
But reset it to release the code BEWARE !! after change the brushes ..
1 close the door
2 program knob to zero
3 program knop to down (like on a watch as a hand pointing to the 6 )wait 2 seconds
4 Now press the speed button and keep it pressed meanwhile pressed the button turn the program knob to like its axis the hands 1one little step to the 7 like the number seven on a watch in comparison
5 after 2 seconds release the speedbutton
If all is right than there must 888 be displayed ..
Finally turn the program knob to 0
Suc6
Dec 23, 2016 | Bosch Washing Machines
Reset pcb bosch classixx 1200 express
There is no reset as such, if the motor shorted when the motor brushes went there is a good chance that it blew the motor tracking or relay on the board. Sometime this is indicated by F20 or F21. Unfortunately this will be a new board. You could try to run a motor test as follows:
Hold in the start button while turning the dial one click to the left (30 easycare) wait until the display shows 888 or two indicators light up next to dial.
Release start and turn dial to 60 cotton (WITHOUT GOING THRO THE OFF).
Press start
This should start a motor test
slow turn one way, slow turn the other, pump on then up to full spin.
(some machines will show the rpm on the display).
If this does not work, you probably need to change the module aswell.
Best of luck
Mar 20, 2013 | Bosch Classixx WFO 2866 Front Load Washer
My Bosch DWM 40L angle finder has locked itself on 888.8 and I can not swithch the machine off, even when I put in new batterie it does not correct itself, please can you help.
Aug 15, 2011 | Bosch DWM40L Miter Finder Digital...
Bosch DWM 40L, Cannot seem to resetit,it reads 888.8,it wount even switch off.
Feb 24, 2011 | Bosch DWM40L Miter Finder Digital...
Bosch dwm 40 L. how do i calibrate it or where can i send it
The manual states this tool needs no calibration. I spoke to the service rep at Bosch, and he confirmed there's not 'published' way to do it. There are a number of outside firms that will do it. If you call Bosch support and explain the problem, they should send you a mailing label and calibrate it properly. Depending on if it's in warranty or not, there may be a fee for calibration and the return shipping.
Feb 21, 2011 | Bosch DWM40L Miter Finder Digital...
Measuring Tools & Sensors Logo
2,306 people viewed this question
Top Bosch Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Bosch Measuring Tool and Sensor Expert? Answer questions, earn points and help others
