Question about Sharp AR-5320 Black and White Copier
SHARP AR 5516 Photocopy m/c display error showing F2
Posted by mubarakpadve on
VINESH T M
  • 21 Answers
Toner chip problem.You should replace the chip.
Posted on Aug 06, 2011
Sharp AR-5516 F2 displayed. go to the service mode (C-interrupt- # - interrupt) and enter 14 but not solved please tell me
Hello Sir,
More exactly what is your error? F2-02 or F2-04?
For F2-04 try to change toner cartridge or verify if the chip on the toner cartridge is correct positioned.
For F2-02 you must verify if toner sensor is not dirt, the toner sensor is positioned on back of developer unit, clean very well.
Best Regards,
Dec 09, 2011 | Sharp AR-5516s
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
My sharp AR 5516 shows f2 04 error code, please what is the solution
You have to change your developer, you can see developer spillage inside the machine it is a common problem in this particular model. Rate this and vote for this after your problem resolved.
May 20, 2011 | Sharp AR-5316 Advanced Digital Imager...
AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE DURRING INSTALATION. WHAT COULD BE THE CAUSE. PLEASE.
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Mar 12, 2010 | Sharp AR-5320 Black and White Copier
H2 problem sharp AR 5516
sharp ar5516 showing code f2 or h2
Jan 14, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Black and White Copier Logo
446 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
