Question about Admiral AW22 Top Load Washer
When the washer is ready to wash,the water keeps coming in to the washer,won't shut off
  • Admiral Master
  • 3,361 Answers
Open the control panel. Remove the plastic hose from the water level switch.
Blow through the hose to remove any blockage from the air bell at the tub. Reattach the hose and set the machine for a SPIN cycle and run the machine. Then re-fill with water.
Double check the hose for any kinks or pin holes.
If this does not correct the problem,the water level switch will need replacing.
Posted on Aug 04, 2011
    New Friend:
String stuck and i need to remove it
Posted on Apr 28, 2012
6ya staff
SOURCE:
110.18522790 washer have to turn off supply lines or it keeps dripping water into the washer
The inlet water solenoids need to be replaced. Appliance parts houses will have them.
Sep 14, 2017 | Kenmore Washing Machines
Only the Cold water washing works. How come when I turn the Hot the water stops
bad water valve on the washer.shut the hot water off at the shutoff.disconnect the hot water hose going to the washer and stick it into the washer or a sink and turn it on,if water is coming out then it's the washer water valve that's bad,the hot water side isn't working correctlypart number .285805 and it's around 30 dollars
http://www.youtube.com/watch?v=Fk4puRv3Vk8
May 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Lavamat problems
Most likely, your washer's fill valve is leaking. You can probably find replacement valves. I found the AEG LAV1480 parts at several sites.
If your water pipes to the washer have shut-off valves where the hoses connect, turn the water to off after doing the wash. If they don't have shut off valves, have them installed. It's a cheap way to avoid floods when either the valve or the hoses fail. There are some high-end electronic shut-off valves that include a timer so you won't forget to turn off the water. Two simple 1/4 turn shut-off valve (one for hot, one for cold) are cheaper but you have to turn off the water after you finish the load.
To test the shut-off valves when in the closed position, disconnect the hoses from the washer and put a bucket under them. No water should flow into the bucket beyond the water that was initially in the hoses.
I hope this helps.
Apr 29, 2012 | AEG Washing Machines
Water won't shut off on my Estate washer
check clear tube that is inside machine.1st take off shell of machine look for clear tube about 1/4 inch diameter.it sometimes comes off,it pushes over nipple to load size water fill knob.if it came off the water will keep on flowing and over flow.if that's the problem just put a dab of silicon on nipple and push tube back on.
Feb 20, 2012 | Estate TAWS800JQ Top Load Washer
GE WSXH208V1WW
Usually when you have a washer that will not drain, first check if the drain hose is kinked or too high above the washer (8 ft is the limit of the washer pump). Next check if there is a blockage in your drain (often a stand pipe) or if the air can't get into the stand pipe. The final thing to check is for foreign objects in the pump to drain hose area that block the drain. (This requires getting into the pump and disconnecting the hose. Keep a bucket ready to catch the water that will pour out of the washer.)
GE has the manuals for many of their appliances on their support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click submit. The direct link to the manual for the WSXH208V1WW is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90256.pdf .
I hope this helps.
(at least my washer won't spin if the water can't pump out. On a few washers (non-high efficiency) the solenoid has failed to open for the pump to drain the water.)
Nov 22, 2011 | Washing Machines
The door lock won't open. I unplugged unit to reset, but still can't open door.
try finding the manual release..on my bosch nexxt 300 there is an access panel on front lower right of unit for the drain if i open it and reach up there is a cable to pull on to manually unluck the door...have wet vac ready as there might be water from a clogged drain causeing washer to keep door locked
Oct 10, 2011 | Frigidaire ATF6000ES Front Load Washer
I get error FE- book says unplug and call a tech. Is this something I can fix myself?
FE error means that the water is filling past it's set point. You may have a broken water valve that won't shut off when it's in the filling mode. You can check by running the washer and watching the water fill. If the water level fills above the bottom of the glass, you have a water valve that's not shutting off. Replace the water valve.
Aug 21, 2011 | LG WM2487H Front Load Washer
Whirlpool front loader -new washer - put in gentle load and keeps shutting off part way with LF -kept trying to start over, even unplug but keeps doing it -have about 5 small items - cold water only -have...
As it's new it will still be under guarantee/warantee? I strongly advise you contact their service desk as you could invalidate the guarantee by following other's guidance. I'm interested in why you have shut off the hot water? Once the temperature is selected by the user, the washer automatically uses a mix of hot and cold water, or just selects cold for rinses etc..
Has the 'LF' been coming on BEFORE or after you shut off the hot water?
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 16, 2011 | Whirlpool Washing Machines
Admiral AW22 Top Load Washer Logo
231 people viewed this question
Top Admiral Washing Machines Experts
jimorris77
Gerry Harvey
Gerry Harvey
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
