TV LOEWE 8784. Died SPP11N60S5 in the power supply. After replacement of the MOSFET the TV worked for a day then next morning it died again on a start. This way were killed 3 MOSFETs. What could be the problem? Please help.
Posted by Sergei Sokolov on
  • Televison & ... Master
  • 17,130 Answers
Possible that when the MOSFET'S were changed the Switch mode oscillations were not proper and so the drivers were driven too much to fail.
It will be best to replace the whole power supply if the mosfets are heating up more than required.
Also replace all the electrolytics and check the SM transformer after the mosfets are replaced and before switch on. Check also the load on the output , if there is any short or leakage on the drive output .
Posted on Aug 04, 2011
No display after installing Biostar motherboard
THE DRIVERS MAYBE ? .
THE MONITOR ? .
YOU HAVE TO EXCLUDE ONE THING AFTER ONE OTHER.
Jun 13, 2013 | Biostar Computers & Internet
Tv was working now it won't power up. Only disconnected mains cable.
This type of fault is a power problem, Power supply board just die.It can be dead at anytime.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck in rectifying the problem....
May 13, 2011 | Loewe Televison & Video
TV will not turn on. Power on the wall socket is good. Worked one day and died the next. Is there a fuse some where inside which may be blown?
No,power supply board have dying capacitors.That the board,where the power a/c cord plug into it.Power supply board,have dying about to be dead capacitors,these capacitors all way bulges up on it tops or puffing up on it tops.U know basic electronic and have tools?Check the power supply board and replaced these dying capacitors,will solved this problems.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Sep 07, 2010 | Initial DTV-262 26 in. TV/DVD Combo
Dead TV Panasonic CT 36HL42CF
have a visitation and bury the next day.
Jul 14, 2009 | Panasonic CT-36HL43 36" TV
Hitachi 51F510 with NO POWER
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule since your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Feb 15, 2008 | Hitachi 51F510 51" Rear Projection...
Loewe Aconda 9381 HD/DR+ Will not switch
Could be loss of voltage on secondary or problem on Power supply. Check 4/5 (depnding on chassis) wickman fuses on secondary if none are o/c then replace power supply components with Kit from Loewe. Part number 90415.900.
Should take tv engineer about 1 hour (max) to replace parts form kit.
Aug 08, 2007 | Loewe ARC332 32" TV
Televison & Video Logo
215 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
