T51211BC is 120Volt timer that can be wired many different ways because there are two internal relays, and each relay has NO and NC terminals. One relay is controlled by timer dial trippers, and other relay controlled by dawn-dusk photo eye
Timer wiring cannot be fully explained with words.
Below is basic hook-up for your 120Volt wiring application, and then you can use a tester and experiment with the knob settings, and tripper settings.
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/24%20hour%207%20day/t50000%20series%207-day%20time%20switch.aspx
1) You have 4 cables:
one cable from circuit breaker box;
one cable going to photo control;
one cable going to outdoor Load (lite);
one cable going to indoor Load (lite).
2) Cable from circuit breaker has 2 wires:
Black Hot wire connects to terminal 1
White Neutral connects to terminal 2
This will power the clock motor and timer relays.
3) Photocell has 3 wires:
Black connects to terminal 1
White to terminal 2
Red to terminal 3.
Photocell turns relay on-off for Circuit B
Do not mix different size wires under same screw terminal, or smaller wire will come loose over time. Also do not mix stranded wire and solid copper under same screw terminal for same reason.
4) Terminals 4 thru 12 are 'dry'.
Dry terminals receive no power when power is applied to terminals 1 and 2.
To put power on dry terminals, so that Load will have power, attach Black hot wire from breaker to terminals 9 and 12.
So add a jumper wire from terminal 1 to terminal 9 and another jumper wire from terminal 9 to terminal 12.
120Volt power is now connected to terminals 1, 9 and 12
5) Circuit B is dawn to dusk for outdoor Load.
Outdoor load cable has Black and White wire.
Connect outdoor Black wire to either terminal 10 or 11.
To test which is correct for your application, set switch to Auto, and then test across terminals 12 and 11, and across terminal 12 and 10. Repeat test after dark. Rotate knob B to each position and repeat test.
Connect outdoor White wire to terminal 2, and this will complete the circuit.
6) Circuit A is Dusk ON and timer OFF
Indoor cable has Black and White wire.
Connect indoor Black wire to either terminal 7 or 8.
To test which is correct for application, set switch to Auto, and
then test across terminals 9 and 8, and across terminal 9 and 7.
Repeat test after dark. Rotate knob B and repeat test.
Testimonial: "thanks for quick reply I will do it next wee"
welcome to:http://www.famalegoods.com
The website wholesale for many kinds of fashion shoes, like the nike,jordan,prada,****, also including the jeans,shirts,bags,hat and the decorations. All the products are free shipping, and the the price is competitive, and also can accept the paypal payment.,after the payment, can ship within short time.
free shipping
competitive price
any size available
accept the paypal
jordan shoes $32
nike shox $32
Christan Audigier bikini $23
Ed Hardy Bikini $23
Smful short_t-shirt_woman $15
ed hardy short_tank_woman $16
Sandal $32
christian louboutin $80
Sunglass $15
COACH_Necklace $27
handbag $33
AF tank woman $17
puma slipper woman $30
