Your washer uses cold water only for the rinse cycle.
Start you washer and put the water temperature switch on 'cold' to see if you have any cold water.
If you find that there is no cold water then turn the water off and remove the cold water hose from the back of the washer.
Once you have the cold water hose removed you will be able to look in the water valve and check the screen. A lot of times the screens get plugged up and need to be cleaned. The screen will just pull out of the valve so you can rinse it out good.
Make sure to put the screen back in place.
If you have no cold water and the screen is clean then you will need to replace the water inlet valve.
