Question about HP Pavilion dv5-1125nr Notebook
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
    New Friend:
  • 16 Answers
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Posted on Aug 03, 2011
  • 4 more comments
  • GeekHick Aug 03, 2011
    Sorry that didn't post correctly:
    LEDs blink 1 time CPU not functional
    LEDs blink 2 times BIOS corruption failure
    LEDs blink 3 times Module error not functional
    LEDs blink 4 times Graphics controller not functional
    LEDs blink 5 times General system board failure
    LEDs blink 6 times BIOS authentication failure
    Link directly to article, since it isn't formatting correctly here:http://h10025.www1.hp.com/ewfrf/wc/docum...
  • loverboyisth Aug 04, 2011
    Thank you so much. I did contact HP and they didn't way anything that i already knew.I told them that the LEDs light near the cap and num lock because i knew it had to have some kind of code. They guy who help me didn't really troubleshoot it at all. I knew it had to be either the GPU on the board or something to do with the overheating which the Dv5 is known for. It's blinking once and then for abit then blinks onces again then stop again. So it's was the CPU. I thought it was just the Thermal paste because it's already hard like clay. So I picked up some thermal paste and hope it will work. I checked today if anyone had answer and it's a good thing you did. So the one blink means my CPU is dead. I guess i need to get a new one. I also have another question on how to stop the overheating the DV5-1125nr? I was thinking of throttle the clock speed, but it wouldnt let me. Would you suggest that i should get a new laptop or just replace the CPU?
  • GeekHick Aug 04, 2011
    If it still is under warranty send it in to have it serviced
    If not under warranty and If it was me I would purchase a new laptop. Best case scenario, the cost of fixing the one you have in the end will probably be half of what a new one would be. Worst case, it would be as much or more than a new laptop.
    Ya it's been almost 3 year and the warranty was up about 2 years ago. Before this i had problems with my battery and adapter so i purchased a new one because before it stopped working then battery icon said that i should get a new battery. I thought that was the problem then i notice the blinking lights. So it was the CPU. Since then I've been trying to look how much a AMD Turion X2 mobile processor is worth and is it worth fixing or getting a new one. Also i had some documents that i would like to get from that laptop from school. All my CNIT work was in there too. I do get another laptop i want to be able to use the SSD so i can remove all my files.
  • Douglas Wiedle
    Douglas Wiedle Mar 12, 2014
    Everything on the hard drive should be intact. Just get an external 2.5" drive case to put the drive in and plug into your replacement computer usb. You can look into the drive by window explorer.
Anonymous
SOURCE:
What does it mean when your laptop's power lights flash ? Including the power button?
"The following table illustrates the meaning of blink codes used on some notebooks with EFI environment.
The blink or beep codes on your computer may have different meanings. When you contact HP for
support, the agent needs to know the model of your computer and may ask you about blinking LEDs
or beeping tones to help troubleshoot a startup problem.Meaning of Sample Blink Codes for some EFI Notebooks Number of Blinks or BeepsLocation of Blinking LEDsComponent Being CheckedError Condition
Continuous glowBattery power LEDBatteryThe AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
1time---Caps Lock/Num Lock-----CPU------------------CPU not functional
2time---Caps Lock/Num Lock-----BIOS----------------BIOS corruption failure
3time---Caps Lock/Num Lock-----Memory-------------Module error not functional
4time---Caps Lock/Num Lock-----Graphics--------------Graphics controller not functional
5time---Caps Lock/Num Lock-----System board----------General system board failure
6time---Caps Lock/Num Lock-----BIOS-------------------BIOS authentication failure
Continuous blinkAC power adapter LEDPower adapter Insufficient power"
Nov 01, 2012 | Compaq Computers & Internet
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
Laptop wont boot up to anything, just a black screen when you turn it on and the light at the cap locks flashes 5 times and thats all.
Number of Blinks or BeepsLocation of Blinking LEDsComponent Being CheckedError ConditionContinuous glowBattery power LEDBatteryThe AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.1Caps Lock/Num LockCPUCPU not functional2Caps Lock/Num LockBIOSBIOS corruption failure3Caps Lock/Num LockMemoryModule error not functional4Caps Lock/Num LockGraphicsGraphics controller not functional5Caps Lock/Num LockSystem boardGeneral system board failure6Caps Lock/Num LockBIOSBIOS authentication failureContinuous blinkAC power adapter LEDPower adapterInsufficient power
Oct 10, 2010 | HP Compaq 6735s Notebook
My laptop will not turn on
Try another AC Adapter with the battery taken out of the laptop. If the light still blinks then that means the motherboard is bad and would need to be replaced.
Jun 01, 2010 | Compaq Evo N1020V PC Notebook
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
Hp compaq powering and nog display what do i do to
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure Well Check for the below link it will provide you the steps which you need to perform to isolate the cause so that we can determine which hardware of the laptop is causing this issue. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&cc=us&lc=en&dlc=en You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Battery
CPU
CPU not functional
BIOS
Memory
Graphics
System board
BIOS
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
BLINKING Num Lock, Caps Lock & Scroll Lock
Put the RAM back in or check the RAM in securely
Apr 13, 2009 | E-Machines AAFQ50400000K0 Keyboard
HP Pavilion dv5-1125nr Notebook Logo
3,024 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
