I threw my remote against the wall ( I know , terrible decision ) , and i put it back toghether after it cam apart , and all the butttons function except the volume/channel/mute button . it won't press down to activate the signal to turn the channel , even though i have taken it apart and tried to figure out the issue , it still won't work . my last resort is to by a new remote ... do you reccomend getting a new one or figuring out what's going on with the old one ?
I suspect remote is unable to communicate with the base and is reporting the issue as power loss at base.
So does the base function, makes and receives calls?
Reset the base unit and power supply by unplugging the base power supply from the wall, wait at least 1 minute, plug base power supply back into wall outlet.
Reset remote by removing battery wait a minute, reinstall battery.
If after the reset the base can't make/receive calls, its likely failed.
If the base works and the remote still reports base power issue, could be either base or remote.
try putting a lighter load in the washer,or you put some foam or something like that at each side of the machine to stop it hitting against the other things next to it.also try adjusting the feet at the bottom of the machine to level it out.
The remote control is dead or the remote CPU chip that control all functions is dying and only some of functions buttons will work,some wouldn't anymore or the rubber insulater between the rubber buttons and the remote circuitry board are worn out and make no more contact.Can u take the remote aparts?Yes.Check all the rubber butttons insulater see if they're still good.Tries clean the remote PC circutries board with some rubbing alchahol also the battery - + connections too.Wait like about 20 mins for the rubbing alchahol to completely dries.Putting it back together again an putting in new batteries,the remote control might work again.If not have same result.Try website like Remotes.com to buy an original or very close compatible remote for a replacement.
That may be, because you were using the Remote Control to operate it, but then turned off the wall switch instead of turning it off using the Remote Control.
Turn the wall switch back On and try to get the Remote Control to take back over the operation. If that solves your problem, in the future you will know to turn off the fan and lights with the remote, before turning off the wall switch.
Hope this helps solve your problem. My wife had to learn the same way with ours.
If you have a IR/UHF remote then the littel white peice go to the switch that tells the remote to send UHF or IR signals. This little white peice will fit on the end or the green board at teh very bottom of the remote, it will slide into place allowing the colored tab to move it back and forth to enable and disable UHF and IR frequencies. These remotes are built very tough, i would say you threw it pretty hard lol. You may need a replacment if you continue to have issues.
Try to have the MMS settings checked through your service provider, they can try to reconfigure the settings on it, since the phone has been reset. But if not the phone got damaged for that incident.
You have to take the whole back off. Take the battery door off.. and then under there there are four more screws. You take those out and pull it apart. Now slip the center part threw the crib rails, snap the battery case back on and put the screws back in.
most universal remotes will not operate menu fuctions or allow input selections. try using channel down buttton on tv . go all the way down to channel two then go down again to see if video1 or 2 comes up. if not access menu functions on front panel go to input select enter in manually mch
don't panic you probably knocked the screens ribbon cable out you will need a special screw driver(ebay).there are many good guides available on taking them apart and putting them back toghether.the trick is to take your time and be very careful.
