Place your cell phone face-down, remove the back cover, remove the battery from its compartment and set it aside.
Remove the Phillips-head screws securing the back panel of the phone. This portion of disassembly varies from phone to phone. Some cell phones require that you pry off the back panel with a thin plastic object such as a guitar pick or credit card. Remove the back panel and set it aside.
Remove the circuit board. This part of the disassembly process varies from cell phone to cell phone. Most cell phones require that you remove the screws securing the circuit board in place. After the screws are removed, you may be able to completely remove the circuit board, but many phone require that you disconnect one or several ribbon cables connecting the circuit board to the keypad, LCD screen and camera. Lift the circuit board out of the phone and set it aside.
Remove the now-exposed LCD screen. You may need to remove a few small Phillips-head screws. Lift the LCD screen out of the cell phone casing and set it aside.
Follow this procedure in reverse to install the new LCD screen into your cell phone and re-assemble the cell phone casing.
